conveted to obd1 ef sedan
Old Apr 19, 2012 | 10:44 AM
vw40life's Avatar
Default conveted to obd1 ef sedan
hello i need some help i have a ef with a b16 swap i have a obd2 dizzy and obd1 p06 ecu the car will not fire up on the obd1 ecu but it does fire rigth up on the obd0 ecu like nothing i cut the original dizzy plugs and spliced them like the boomland said the color code are it does have obd1 injectors also
Old Apr 19, 2012 | 11:13 AM
4drEF's Avatar
Keyboard Humorist
Default Re: i conveted my car to obd1 ef sedan
Are you getting spark and fuel?
Is mechanical timing set correctly?
Any CEL with ECU codes?
Old Apr 20, 2012 | 01:03 PM
vw40life's Avatar
youp has spark and timing is perfect it only fires up on the obd0 ecu and then it acts stupid and will not fire up on the obd1 ecu bro
Old Apr 20, 2012 | 01:58 PM
4drEF's Avatar
Keyboard Humorist
Default Re: conveted to obd1 ef sedan
Get a different OBD1 ECU to test with.
If that fails, then your conversion harness is bad.... not as uncommon as one might think.
Old Apr 20, 2012 | 05:09 PM
JustHonda2's Avatar
hey man im having similar issues, i have a 1990 civic hatch dpfi i wired in the boomslang harness and have tried several ecus im running d16y8 with obd2 dizzy and obd1 injectors the car runns good just wont rev over 4000 rpms, i think its these bs harnesses, what ya think
ricardo13d
11
Dec 8, 2011 06:55 PM
daidilus
Feb 9, 2005 05:13 PM
wsiracerz
May 25, 2004 08:41 PM
