How to rebuild TD-05H Link.
Old Apr 19, 2012 | 08:27 AM
zerovandez's Avatar
Default How to rebuild TD-05H Link.
I recently acquired a Greddy TD-05H 18G turbo and came across this link.
http://www.mitsu-media.com/showthread.php?t=9948
I thought it was worth sharing for those interested in rebuilding their turbo's.
Old Apr 19, 2012 | 08:46 AM
boosted_D's Avatar
Default Re: How to rebuild TD-05H Link.
That's all fine and dandy, But where does it account for balancing the turbo? It doesn't, because you cant do it on your own, a pro has to do it.
If your lucky 1 in 100 turbos might turn out to be balanced enough with no proper balancing job and will work fine, the other 99 will self destruct in a matter of no time because they are not balanced.
You know how a motor revs to lets say 7000 to 9000 rpm, and the crank/rods/pistons (mostly the crank) have to be properly balanced or the motor will self destruct...
A turbo spins at 200,000+ rpm, in no way is it ok for it to be off balance by even a tiny bit.
Old Apr 19, 2012 | 09:01 AM
TheShodan's Avatar
Moderator
Thanks for the info. This is always helpful Go ahead and contact the moderators to see if this can be made as a "sticky" to the FAQs.
Old Apr 19, 2012 | 09:08 AM
zerovandez's Avatar
I agree. At what step should one send out parts to be balanced and what are the included parts?
Will do!
There are also a few points in the below link about balancing. Are they true?
http://gpopshop.com/services/turbo-balancing/
Old May 4, 2012 | 09:06 AM
zerovandez's Avatar
This one is also very good!
http://www.6thgenaccord.com/forums/s...ad.php?t=38215
Freshdot
Aug 21, 2011 07:07 PM
nh4442
May 12, 2005 11:23 AM
CivicRaping
Apr 15, 2005 11:08 PM
ITR.00-1282
Mar 13, 2003 08:58 AM
