Reving at 7200rpm which it suppose to be 7900rpm
Old Apr 19, 2012 | 08:15 AM
rvang10dc5's Avatar
Icon2 Reving at 7200rpm which it suppose to be 7900rpm
Having problems with my rsx. I change out the starter since it dead on me. After that car won't start. change the ground wire and car starts fine. Was testing the car out to see if anything was wrong. So took it out for a run and was redlining at 7200rpm. The check engine been on but when i first had it, it the cel been on and was redline at 7900. Got any idea what is wrong? The cel throws out p0420.
Old Apr 19, 2012 | 06:33 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: Reving at 7200rpm which it suppose to be 7900rpm
Did you disconnect the battery when you took everything apart to change the starter?
Clear the code once and take it for a spin
then stop abusing your car and fix the problem causing your CEL.........
EFmine
Sep 11, 2013 02:50 AM
biev
Jun 26, 2007 03:30 PM
DarkBB4
Apr 23, 2007 10:47 AM
teknikEG6
Apr 15, 2006 03:04 PM
BigDawwg6969
Oct 5, 2003 10:08 AM
