NGK Spark Plug Wires - Which Part #??
Old Apr 19, 2012 | 05:12 AM
JZiggy's Avatar
Default NGK Spark Plug Wires - Which Part #??
I'm freshening up the engine bay of my stock 95 Civic LX (D15B7) and wanted to get some NGK wires to replace the old Prestolites.
1st Attempt: Looked up the application on NGK's website which called for HE71 wires. Coils are too long and stick out of the valve cover. Returned to Amazon.com.
2nd Attempt: Looked up application on RockAuto.com and double-checked at Amazon -- HE76. Okay, these ones fit onto the spark plug and are the right length, but the dust boot is too small and does not cover the spark plug hole. The internal seal that keeps the coil from wobbling around inside the hole is also too small. Returned to Amazon.com.
I'm reading now that NGK wires spec'ed for older generation Civics (88-91) fit here, which is NGK part HE53. This is the next thing I will try.
Can anyone confirm that this part # works on their D15B7 motor?
Old Apr 19, 2012 | 05:23 AM
EsotericImage's Avatar
Retired Moderator
Default Re: NGK Spark Plug Wires - Which Part #??
Why not goto your local auto parts store and get the NGK's that you can test fit in the parking lot? seems a helluva lot easier then then you waiting 2-3 weeks for a set after buying and returning.
Old Apr 19, 2012 | 05:58 AM
JZiggy's Avatar
Good idea, I'm going to hit Advance today and try out the HE53's.
The buying/returning is not so hard with Amazon prime though.
Old Apr 19, 2012 | 06:14 AM
94EG8's Avatar
Seagull Management
'88 - '91 civic plug wires should fit fine. They use the same style head and valve cover.
Old Apr 19, 2012 | 07:57 AM
motegicivic's Avatar
HE76 For my d16y8, is your engine set like that, dizzy on left side I assume, so they are sweet wires.
Old Apr 19, 2012 | 02:54 PM
s13hero's Avatar
Weird, I use HE71 on my 1995 DX with a D15B7
Old Apr 19, 2012 | 04:21 PM
94preludeguy's Avatar
I just bought a set of new NGK HE53 wires on eBay for $27 shipped.
Old Apr 19, 2012 | 04:34 PM
94EG8's Avatar
Seagull Management
Y8 wont work. D15B7/D15B8 are different from all other '92 - '00 D-series.
Old Apr 20, 2012 | 08:53 AM
JZiggy's Avatar
The HE53 wires work great and fit great. Thanks for everyone's input.
Not sure what happened with the HE71 and HE76. Perhaps the "right" part # happened to be the wrong part in the right box??
I'm also happy that these new wires are 8mm and are replacing some 7mm Prestolites.
Old Apr 20, 2012 | 09:03 AM
furious94ls's Avatar
Buy OEM wires, wrap blue painters tape around them and write NGK in black marker.
Old Apr 20, 2012 | 11:24 AM
NGKs are usually cheaper and are just as good if not better then OEM.
Old Apr 20, 2012 | 11:30 AM
94EG8's Avatar
Seagull Management
They're close to OEM, not quite as good though. Temple of vtec compared them to old *** stock 15 year old OEM wires years ago on a dyno. 15 year old OEM wires made slightly more power than brand new NGK wires.
Old Apr 20, 2012 | 11:42 AM
OEM is cheaper too
Old Apr 20, 2012 | 02:01 PM
OEM is cheaper too
Where? I don't think I've ever seen a set of OEM wires for cheaper then $27.
zellmk
Dec 9, 2015 09:53 PM
AdammBone
Mar 10, 2015 11:19 AM
Jhicks
Mar 7, 2012 05:39 AM
95civichybrid
May 9, 2003 07:28 PM
KF_S2000
Feb 2, 2002 06:08 PM
