94 Del sol build!
Old Apr 18, 2012 | 07:40 PM
demon del sol's Avatar
Icon3 94 Del sol build!
.. i also need some additional info on motor swap and tranny conversion...thank u ! to whoeever helps me.!
Old Apr 18, 2012 | 07:48 PM
SpikedInterest's Avatar
Default Re: 94 Del sol build! need parts!
Just as a tip, you should always include pictures and what you are doing/plans and people will be more encouraged and more considerate in helping you out. Especially on the motor swap and tranny conversitions. When it comes to a motor swap you should atleast list what application your leaning towards and what you have in mind, especially what your budget is. Which will give more knowledgeable users information about what you're doing so they can help you out.
I'm not trying to bust your *****, far from that. Just trying to give you a tip.
Old Apr 18, 2012 | 08:12 PM
ohhh ya im trying to right now its not a copy n paste kinda thing...but when i upload ppics ill list everything...nd i kno ur not bein a dick thnx
Old Apr 18, 2012 | 08:18 PM
Read this; https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/rules-thread-titles-car-information-searching-trial-users-picture-posting-3002401/
That should answer your photo problems.
Now what were your plans for the motor swap?
Old Apr 18, 2012 | 08:34 PM
see how its bent back on the left side ^^
normal^^
somewhat fixed ^^
im looking to do a b18c1 tranny conversion on boost as well with fully built internals....listen tht sentence alone is expensive and i know it..yes i make enough money and this car will also be a build so not to big a rush especiialy wen my dd motor is running solid and i have to build the motor outside the car n e ways ...so financially ill b ok, i kno the motor and tranny alone will run me 3k not including tranny conversion parts and all the axles i neeed and shift linkage all the **** ...but what i do need help with is what axles i will need and which kind of parts i need for the the motor...is this better??
Old Apr 19, 2012 | 07:39 AM
Icon2 Re: 94 Del sol build! need parts!
ok so my del sol is white with a dark blue dash board and flat black as u see air vents...i want to paint them but idk if i should paint them white and have them stand out like alot or i should stay subtle and go shiny black and paint the centter consoles the same blue.....or black...idk what looks good and im trying to stay away from tht ricy ****...i jus want it to look nice.
ok so i bought this radio and it has a pop screen now in the del sol's the radio sits back in it but if i cut tht top part off the middle console do u think i could make it fiit and b able to pop out.....also its a black radio with white numbers....if u kno what i mean...i have black carpet as well
door panel driver side....
ok so i wana put tweeters in the door panels....and i was wondering if this spot would be possible to do..or if anyone has a better input plz lmk
http://i42.tinypic.com/4g1c9v.jpg
Old Apr 19, 2012 | 08:52 AM
Former User's Avatar
Selling or buying is forbidden in tech forums. Post ads in the Marketplace when you get beyond Trial User status.
http://www.hondamarketplace.com/
Old Apr 19, 2012 | 04:31 PM
salaamq's Avatar
Tweeters would fit there. Honda actually had an option of tweeters in the JDM market,I believe also the EDM, and thats where they put them.
Old Apr 19, 2012 | 05:45 PM
gzes's Avatar
dude ur radiator core looks alot different from mine lolim getting the thought that i have a civic radiator core... i mean if so then i can drop a new one in and have a non screwed up support...
Old Apr 20, 2012 | 10:43 AM
97 DelSol SI's Avatar
You have an aftermarket radiator i believe. It looks aluminum i do believe. If you are wanting to switch it out, Koyorad makes a double wide aluminum radiator for the integras that will interchange for the eg2 i do believe if i'm not mistaken that would work well for the b16 on a light budget
Old Apr 20, 2012 | 12:31 PM
gzes's Avatar
Yea its aftermarket I bought it for $66 and since the radiator core is bent the radiator gets hit so I need to replace the core but am confused on wether the core is from the del sol or a civic since it has a civic conversion... Any help would he great thanks
Old Apr 23, 2012 | 08:07 AM
unless the whole front clip was replaced, it should be a Del Sol radiator.....however it is probably the same either way. Really shouldn't matter
Old Apr 23, 2012 | 08:12 AM
Back to the subject of the thread.....i looked at a flip screen for my sol too....unless you get one that you can adjust the screen tilt internally with the headunit then the AC controls will hit it too....unless you fab a setup to go in the top vent hols above the AC controls i believe you're out of luck on this one
Old Apr 23, 2012 | 08:32 AM
gold_pwr_r4ng3r's Avatar
I just put one in my del sol over the weekend. i ended up leaving it pulled out a little bit.
HankTrigg
Aug 3, 2008 09:57 AM
dom5372
Feb 14, 2005 05:24 PM
