91 civic fuse box.... need help asap!?!?!?!?
What is the relay all the way up and all the way to the left?
My ignition plugged in right under that and i got power when i turned the key at the plug but not at fuse #2. So is the fuse box messed up or is one of these relays bad?
Check your fuses to be sure.
If you're getting like 6V to your fuel pump, it's your main relay. You can try to resolder the connections or buy a new one for about $55.
Located behind the ashtray.
Replaced the main relay.... triple checked all my fuses. Unplugged the fuse box and it like fell apart. I ordered another one for 30 bucks..... sure hope it fixes my problem.
92hybridAccord
Apr 6, 2005 10:09 AM
