b16a starting up problem
Old Apr 17, 2012 | 07:49 PM
toby350's Avatar
Default b16a starting up problem
ok i have a 92 si with a b16a. I changed the cap and rotor on my dizzy and i turned on the car and it turned on fine. After i changed the cap and rotor i changed the hoses that goes from the intake manafold to the brake booster. After i did that i went to go turned on my car and it cracked for about 5 to 6 seconds then turned on and befor it would still lag a lil but not as much as it is now. I put the old cap and rotor back on to see if the new ones i put were diffective but it still did it. I also put the two old hoses back and it still did it. So if anybody has any ideas on how i can fix it pls let me know
Old Apr 18, 2012 | 05:34 AM
motegicivic's Avatar
Default Re: b16a starting up problem
I would check the coil.
Old Apr 18, 2012 | 07:50 PM
toby350's Avatar
I put my friends dizzy and the problem went away so i know its something with the dizzy. So i changed the coil and igniter on my dizzy and the problem was still there so now i dont know wat it could be??...may be the wire??..any other ideas
Old Apr 18, 2012 | 08:32 PM
kaves420's Avatar
check map sensor
Old Apr 18, 2012 | 08:47 PM
jbpnoman's Avatar
You know that a new distributor will fix the problem. Just buy a new distributor.
Kaves, RTFT.
Old Apr 19, 2012 | 09:40 AM
toby350's Avatar
Its not the map sensor because when i put my friends dizzy it went away..and im not gana go spend 200 dollars on a new dizzy wen mine was workin just fine 5 mins befor it started happening. And i had a loose wire so that was my preoblem.
ryanhauk
Mar 21, 2010 12:45 PM
theczechone
Jun 24, 2009 07:31 AM
citrus3000psi
Aug 14, 2007 07:25 PM
95 Civic Ex
Sep 29, 2006 02:41 PM
tgreaves
Sep 1, 2005 06:10 AM
