97 Civic EX - code 14
ok, so my 97 ex civic was running fine. did a fluid flush (brakes, transmission, clutch and power steering) then used seafom to clean carbon xdeposits. then next day code 14 (iac). i have replaced it 3 time all with brand newe denso replacements. also wapped in a new battery and still same issue. i have done everything i can think of short of building a new harness. am i missing something?????????
Same issue here.. I've tried 4 different iacv's and the CEL just keeps coming back. Only stays off if i use a pr4 ecu over the p75 I want to use. Idle still isnt consistant. 94 LS motor tho.
got it checked out, and so far for 2 weeks no check engine light. looks like problem was ECT, water temp switch and Fan switch. ecu was receiving a signal of 225 degrees while the gauge was only reading 1/4 of the way.
so far no problems
so far no problems
You never mentioned an idle problem.
When an OBD2 car like yours throws code 14, you should next pull the OBD2 code with a code reader. Had you done this, you almost surely would have retrieved P0505. One possible cause for P0505 is a bad ECT sensor.
i had to use the snap on reader from the shop owner i know to find out the temp readings.
Let me try to explain. Jumping the service connector retrieves OBD1 version CEL codes from 96-00 Civics, even though they have an OBD2 ECU. OBD2 codes, however, yield more detailed information. For example, if you jump the service connector and retrieve code 14 from a 96-00 Civic and then use a code reader to retrieve OBD2 code, you will recover one of two codes - P0505 or P1508/P1509. (There is no P0515 for our Civics.) These OBD2 codes indicate a different type of problem in the idle control system and therefore are more help in pinpointing the problem.
i used the snap on scanner and saw the info i mentioned above.
sumocivic
20
Oct 4, 2011 10:39 PM
nicefighter80
Jan 15, 2011 08:53 AM
