91 civic hatch just clicks once and doesn't start
Old Apr 17, 2012 | 05:52 PM
osbunjosh's Avatar
Default 91 civic hatch just clicks once and doesn't start
I just swapped a d16z6 into a 91 hatchback. All the lights come on and the engine light clicks off. Then i try to start it and it just clicks once. No start. I don't even hear the fuel pump prime. What fuse is for the fuel pump? i don't have the diagram under the dash or on the fuse panel under the hood. I cleaned the battery terminals. Any ideas?
Old Apr 17, 2012 | 05:59 PM
osbunjosh's Avatar
Default Re: 91 civic hatch just clicks once and doesn't start
bump
Old Apr 17, 2012 | 06:05 PM
civicsi_guy's Avatar
really you bumped after 7 min lol. check that the engine isnt seized and actually turns freely also the starter could be no good
Old Apr 17, 2012 | 06:08 PM
KINGVEM^^ED6's Avatar
Check ALL fuses
Main relay
Grounds
Old Apr 17, 2012 | 06:14 PM
osbunjosh's Avatar
would the tranny ground have any effect on the clicking? i even took jumper cable and use both negative side and put it on the start and the frame and still nothing
osbunjosh's Avatar
I heard the engine start before i pulled it....
Old Apr 17, 2012 | 06:15 PM
If the tranny isn't grounded the car WILL NOT start
Old Apr 17, 2012 | 06:17 PM
osbunjosh's Avatar
but i used jumper cables to the tranny? where is the d16z6 tranny ground?
Old Apr 17, 2012 | 06:19 PM
osbunjosh's Avatar
and the tranny ground effect the fuel pump not priming?
Old Apr 17, 2012 | 06:21 PM
the starter clicking means its getting a signal, but if the starter is bad then at times it will start and at other times it will just click and nothing else try to tap the starter while trying to crank the engine sometimes they get hung up
Old Apr 17, 2012 | 06:36 PM
jdmboyef9's Avatar
Could also be a dead battery...You can try this to check the starter. Put into first gear with the parking brake off and rock the car back and forth. This will slowly turn over the engine and move the starter. It might start after that
Old Apr 17, 2012 | 06:43 PM
that wont move the starter because the starter isnt engaged unless your trying to crank the car. if that were true your starter would be consatntly spinning while driving
Old Apr 17, 2012 | 10:59 PM
93delsold16z6's Avatar
The guy above me is right. The pinion gear in the starter only comes out when needed to turn the flywheel. It wont come out if not getting enough power, or the hold in solenoid went bad.
Old Apr 18, 2012 | 06:58 AM
osbunjosh's Avatar
Okay. The starter doesn't click. Its coming from under the dash by like the ecu.
Old Apr 18, 2012 | 08:51 AM
osbunjosh's Avatar
My smaller start wire does not have power... my dash lights come on and the engine light clicks off. But the FUEL PUMP DOES NOT PRIME. What could cause the fuel pump not to prime and the starter wire to have no power? iv checked every single fuse. my battery is 100% charged.
Old May 16, 2012 | 08:01 PM
Main relay? Grounds?
92IntegraPOS
Dec 30, 2008 08:36 AM
slowcrxsib16
Aug 10, 2006 02:11 PM
ekVtecPower
14
Mar 27, 2006 08:47 PM
fracas
26
Dec 11, 2005 08:59 AM
Quad-Damag
Oct 2, 2004 02:45 PM
