B16A running rich
Old Apr 17, 2012 | 01:49 PM
civicracer1997's Avatar
Default B16A running rich
I have a b16a in a crx. Car was running fine 2 years ago when it was parked. I recently replaced the battery and now the car is running rich and refuses to idle after warmed up. I have changed the injectors ecu fuel filter o2 sensor cleaned the iacv and checked the timing. Also replaced the cap, bug and plugs. I'm not running a fitv and checked the timing. No cel's. Can someone tell me what I'm missing
Old Apr 17, 2012 | 11:11 PM
93delsold16z6's Avatar
Default Re: B16A running rich
injectors stuck open?
Old Apr 18, 2012 | 02:56 AM
HotCheetos's Avatar
213374U's probably gonna yell at me for this but, perhaps resistor box? If you still have one that is.
Old Apr 18, 2012 | 10:37 AM
crxin's Avatar
well if your car is not ideling after it is warmed up, then your iacv is to blame. They have a very high fail rate.
How do you know that they car is running rich? Is it fouling plugs? Do you have an air/fuel guage on the car? When a car decelarates it runs lean, and if your car's idle is messed up because of the iacv it technically should be leaning itself out because it cant catch the idle.
be18see1
Engine Management and Tuning
13
May 28, 2011 05:42 PM
mikeunreal2
29
Mar 22, 2006 06:26 PM
vtecb20coupe
Sep 19, 2005 05:21 AM
mario82686
14
May 7, 2004 09:11 PM
