Old Mar 25, 2015, 09:16 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Hitachi Dist. seal replacement help
Old Apr 17, 2012 | 12:20 PM
Duaber's Avatar
Default Hitachi Dist. seal replacement help
Hello I am trying to replace the internal seal on the Hitachi dist. on my 1997 ex and I can't seem to find the c-clip that holds the pin on the camshaft key. I've tried pounding the pin out but its not budging. Is there any CD5 Ex's that have done the seal replacement that can help me?
Old Apr 17, 2012 | 12:25 PM
Dc4LsTeG's Avatar
EK9
Default Re: Hitachi Dist. seal replacement help
Are you trying to change the seal(oring) pictured?
Old Apr 17, 2012 | 12:27 PM
Duaber's Avatar
No thats easy i'm trying to replace the internal hard seal behind the shaft
Old Dec 2, 2012 | 04:07 PM
crwhite1955's Avatar
Did you ever figure this out? The posts I saw also referenced C clip and washers, but the Hitachi distributor on my 99 Accord looks like your picture. I ended up pounding it out part way with a simple counter sinker, then a steel screw that fit in the hole. There's nothing else holding it on - then the shaft just slips out. Nicked the key somewhat, and also ended up nicking the pin hole in the shaft - did not come out easily - but got it all back together ok. The seal I found in this article didn't fit so well - seemed too big. https://honda-tech.com/forums/showth...stributor+seal
Old Dec 3, 2012 | 06:29 AM
KWayRacing's Avatar
Yeah that pin is press fit in the shaft.
Old Apr 16, 2013 | 07:25 PM
jkowtko's Avatar
I don't think that pin is simply press fit in. I gave it a pretty good whacking with a hammer and punch and it felt like there was metal resting on metal in there. Almost as if the pin has a ledge inside and you have to push the cam fitting onto the shaft a bit to clear the ledge. (But I couldn't budge the cam fitting either).
It is possible that the pin has sprung barbs in it, in which case the pin will never come out this is a single-use distributor. I find that a bit hard to believe they would design it that way.
Has anyone tried drilling out the pin or cutting off the cam fitting to see what's in there?
Again just to be clear, this is the Hitachi distributor, used on the VTEC enginers, not the regular one that has a circlip holding the pin in or in which you replace the shaft seal from the inside.
Old Apr 16, 2013 | 07:34 PM
holmesnmanny's Avatar
over time I'm sure that thing just binds in there. You just need a punch. http://en.wikipedia.org/wiki/Punch_%28tool%29
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-internal-seal-distributor-internal-oil-leak-2214402/
Old Apr 16, 2013 | 07:41 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
it's a tapered pin, are you driving it the right way?
Old Apr 16, 2013 | 09:35 PM
jkowtko's Avatar
tried both ways ... felt like metal hitting directly on metal in both directions.
Old Apr 17, 2013 | 07:34 AM
it's not anything special just a roll pin i have taken apart dozens of hitachi dizzys
Old Apr 17, 2013 | 08:51 AM
jkowtko's Avatar
I destroyed my punch (flattened the end) when I tried to take this out. I'll try again this weekend, from both ends, if you think that's really the case, and I will post pics. If you say the pin is tapered, I should be able to measure the different in pin hole diameter with my caliper, right?
Thanks. John
Old Apr 17, 2013 | 10:41 AM
GhostAccord's Avatar
Try applying heat to the shaft prior to punching out the pin. If that doesn't work then you may need to use heat and a press.
Old Apr 18, 2013 | 12:03 AM
Shoot it with some pb blaster and let it sit for a couple hours.
t0p_sh0tta
May 2, 2012 11:08 AM
sublime423
Jul 12, 2011 04:00 PM
BLaz3ing
Jul 5, 2009 03:09 PM
04silvep3
Dec 8, 2008 10:54 AM
b_serious
Nov 25, 2005 02:22 PM
