Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
B series alternator bracket
Old Apr 17, 2012 | 11:28 AM
known's Avatar
Default B series alternator bracket
So I have just found that I have broken my 3rd upper alternator bracket??
2 metals ones and now a cast piece I thought might be stronger....
WTF
Im lost on this one.
I run the alternator with the shortest belt I can but I dont see how that would break the mount?
Mount on the left is what has been breaking.
Old Apr 17, 2012 | 12:26 PM
JW racing's Avatar
Default Re: B series alternator bracket
Where is it breaking on you Corey? It could be from too much belt tension.
Old Apr 17, 2012 | 12:36 PM
dirty19's Avatar
Ridin Dirty in Cali
I have to concur with Dr. Justin...
However id like to see the films more closely before I make a diagnosis.
Too much testosterone Corey?
Think back to the day you installed it.. hmmmmmm.
Scratches head
Old Apr 17, 2012 | 12:52 PM
JW racing's Avatar
Other than the belt tension the only other thing that could cause a bracket failure is vibration. I broke power steering pump mounting bolts on my K motor for a long time untill i built a brace for it. Since it has a spring loaded tensioner for the serpantine belt I assumed it was not the tension but the vibration and sustained RPM.
I must admit I have never seen the heavy cast brackets break only the cheaper steel ones. The Integra Type R even uses light aluminum cast ones iirc.
Old Apr 17, 2012 | 01:33 PM
Robin6's Avatar
What type of engine mounts and bushing are you running?
A cast metal support like in your photo, well, they are damn hard to make fail.
It could be just blind luck that yours failed, a defect of some sort? Ive never heard of these failing in the past 20 years...
Last thought, is your alt going bad? Causing drag on the pulley and pressure on the mount?
Old Apr 17, 2012 | 01:46 PM
JW racing's Avatar
Good point, I was thinking of the Alternator binding/drag scenario but I was like nah I am sure Corey handles that he seems like he takes good care of his car.
Old Apr 17, 2012 | 02:24 PM
dirty19's Avatar
Ridin Dirty in Cali
Ahhhhh good one Dr. Larry... Well Corey.. what have you found out?
Paul who feels like he is watching an episode of "House" waits patiently for the test results
Old Apr 17, 2012 | 02:46 PM
Robin6's Avatar
If his alt was going out [bearing] then the belt would "squeal"...right? That is where I was going in my head...
Old Apr 17, 2012 | 04:05 PM
Erik95LS's Avatar
It's not Lupis.
That is odd. I can't say I've ever seen one of those break.
Old Apr 17, 2012 | 04:43 PM
dirty19's Avatar
Ridin Dirty in Cali
Originally Posted by Erik95LS
It's not Lupis.
Yea I have to concur... Sounding more like bracketcrackitus syndrome.. Very rare affliction indeed.
Old Apr 17, 2012 | 04:54 PM
known's Avatar
sighhh....I guess I didnt notice since I have been tracking the car only for a couple years now.
So radiator blew up, this happened, welcome to racing right! Im just glad this happened now instead of next week at Roebling or Daytona in 2 weeks.
Basically everything on my car is new.....except my alternator.....that just recently sounds like this:
http://www.youtube.com/watch?v=9gLN3QoN-q8
Thanks guys, it was not making noise until right now which I thought was due to the broken bracket.
Sorry for the deliverance reference lol
Old Apr 17, 2012 | 06:20 PM
dirty19's Avatar
Ridin Dirty in Cali
ohh that was an ugly one.
so it was actually squeeling.
Was there any drop in voltage?
Dr Larry.. looks like your diagnosis was correct?
Old Apr 17, 2012 | 07:49 PM
1998GsRIntegra's Avatar
I see we have many honorary doctors in here. Lol
I was going to say if he managed to over tension the belt to the point of the bracket breaking, the belt itself would be squealing like the alternator is now.
Old Apr 17, 2012 | 08:42 PM
Robin6's Avatar
...so what you are saying is he should have "known"?
Old Apr 17, 2012 | 08:43 PM
known's Avatar
The squealing goes away after start up. I do not have a voltage gauge hooked up so I have not seen any drops at all. It seems odd that it would be bad but I guess it could be....
The tension is always set on the tighter side but you can still twist the belt in the center left and right.
I will probably go pick up a reman. denso and see if I can repair that mount.
I still find it hard to believe I could have tightened it 3 times, enough to break 2 steel, and one cast piece.
Old Apr 17, 2012 | 08:49 PM
dirty19's Avatar
Ridin Dirty in Cali
check the voltage for shizzles and grins.
Let us know what you find.
Old Apr 17, 2012 | 08:59 PM
known's Avatar
I will have to find my meter.
Paul I will try to get that sticker out to you soon, been swamped at work.
Old Apr 17, 2012 | 09:01 PM
sanimalp's Avatar
$cat /dev/urandom
I didn't see a car type mentioned, but on the EF, you have to put a pretty good dent in the body to clearance the b alternator. Are you in a chassis that requires the dent that maybe doesn't have it? IDK.. I am just asking dumb questions, cause I haven't heard of that issue either.
Old Apr 17, 2012 | 09:07 PM
known's Avatar
95 Civic HB, no clearance issues.
I just ordered a new alternator, I dont have the time to mess around with this.
Old Apr 17, 2012 | 09:15 PM
dirty19's Avatar
Ridin Dirty in Cali
Whenever you get the time Corey.
Old Apr 18, 2012 | 07:31 PM
Oh haha, your just as much of a sarcastic smart *** as I am. I was actually implying we have several Jeremy Clarksons in here sporting their honorary doctorate degrees.
Old Apr 19, 2012 | 06:30 AM
solo-x's Avatar
You never answered, where is the bracket breaking? My bet is that you have something out of alignment somewhere and that is leading to the bracket breaking.
The ITR alternator brackets are NOT aluminum.
If the bracket is breaking due to over tensioning the belt (I HIGHLY doubt that), you should pull the oil pan and check your crank bearings. The PO of my ITR over tightened the timing belt and accessory belts and you could see excessive wear on the bearings and cam journals. Mine weren't so tight to break the alternator bracket though.
Belt squeal on startup is typical of a loose belt. If it goes away right away, you've tensioned the belt perfectly for a race car.
Finally, I don't think you're alternator is at fault here. Check the voltage output at idle with and without a load just because and make sure everything is lined up square when it's installed. Then tension the belt _just_ enough so it doesn't squeal. (that gives you a tiny fraction more hp too)
Old Apr 19, 2012 | 08:02 AM
known's Avatar
The break is just to the left of the right mounting point..I don't have pics yet.
The other brackets broke on a different motor I had in the car.
The mounts are just the typical black hasports so not like they are solid teeth rattling.
bseballkid1990
Apr 27, 2012 08:47 PM
lude98SH
Aug 12, 2007 05:48 PM
soon2bdropped
Apr 3, 2007 07:44 PM
StrikerX
Apr 6, 2005 06:54 AM
