DC Sports header has bad weld causing air leak at Oxygen Sensor
Old Apr 17, 2012 | 01:30 AM
holmesnmanny's Avatar
Default DC Sports header has bad weld causing air leak at Oxygen Sensor
What a joke. I just realized when doing an intake manifold gasket replacement that the weld that goes around where the oxygen sensor piece was welded on has a tiny leak there. I can see where's it's black where the exhaust gases were leaking out as it stained around the hole. I am going to use red rtv to seal it. I was going to also throw some jb weld around it but I think it will seal for now. I went over the entire pipe again and it doesn't appear to be leaking anywhere else but there was a spot on the opposite side of the circle of the metal piece where it appears it was going to open up so I rtv'ed all around the piece to be on the safe side.
Old Apr 17, 2012 | 08:41 PM
nus_dogg's Avatar
Default Re: DC Sports header has bad weld causing air leak at Oxygen Sensor
That sucks.
Old Apr 18, 2012 | 01:23 PM
Nachooo's Avatar
are those H22A4 headers?
Old Apr 18, 2012 | 02:43 PM
minilogoguy18's Avatar
That's why DC headers suck, mild steel rusts and the coating flakes over time.
survivalskater
Jan 3, 2015 05:29 PM
LeegodaEG
May 6, 2013 05:14 PM
AlphaQup
Oct 28, 2003 03:53 PM
CivicPete
May 25, 2002 09:44 AM
