oil in spark plug holes
Old Apr 16, 2012 | 01:47 PM
wanting an EF's Avatar
Default oil in spark plug holes
so i found oil in the spark plug holes and the plugs look to be fouled out, is that the reason why it will turn over but wont fully start?
Old Apr 16, 2012 | 08:22 PM
minilogoguy18's Avatar
Default Re: oil in spark plug holes
Highly possible, go to the dealer, buy a valve cover gasket KIT and plugs, oil on the plugs ruins them. It's a good of place to start with your problem of not starting.
Old Apr 18, 2012 | 07:22 AM
razorlude's Avatar
too much oil in the plug chamber will cause misfire but i don think that will cause you No Start.
h22 can be started with just any 3 of spark plugs only are firing....of cos a sluggish starting.
Old Apr 18, 2012 | 07:29 AM
Maluko's Avatar
do these have those o-rings too? not the spark plug tube seals*
Old Apr 18, 2012 | 08:09 AM
97ludedude's Avatar
the gasket kit consists of: valve cover gasket, spark plug tube seals, and the grommets for the studs.
potatointegra01
Apr 14, 2015 03:49 PM
qhiggy
10
Mar 3, 2015 08:49 PM
1998_4dr_gsr
Apr 13, 2011 09:02 AM
aWeimaraner
Jan 25, 2008 10:52 AM
BB6racer
Jan 18, 2006 05:20 PM
