Cheap skinnies?
Old Apr 15, 2012 | 11:39 PM
porkythegrunt's Avatar
Default Cheap skinnies?
Does anyone here run cheap skinnies (tires)?
If so, what kinda tire/wheel setup is it?
And how does it look?
Thanks!
Old Apr 15, 2012 | 11:44 PM
Garage 808 Hatch's Avatar
Default Re: Cheap skinnies?
VX wheels with 165R13 tires
Old Apr 16, 2012 | 01:17 AM
Zer0_SpeedWorks's Avatar
I think i saw here before that some of the guys over thailand or malaysia are using motorcycle tires in their skinny rims.
Will try to look for the link.
Old Apr 16, 2012 | 04:08 AM
SPOOLINmatt's Avatar
lol thats smart if the tires aren't as much as typical skinnies, which are WAY over priced.
Old Apr 16, 2012 | 04:51 AM
Here in my country when there was no slick dealer, i tried to canvass on how much would it cost and its cheaper here. Almost half the price. But then again thats here in my country.
Also no point of running it cause there is MH distributor here already.
Old Apr 16, 2012 | 05:44 AM
portenio78's Avatar
VW 145-15. Yes even the domestic guys run them up front.
Old Apr 16, 2012 | 11:34 AM
Awesome, thanks guys.
Old Apr 16, 2012 | 03:13 PM
89efhatchy's Avatar
When I had a pair of weld magnums on my neon, I used a pair of 165 Federal tires. I think I paid like $110 new for the pair, mounted and balanced. The weight of a street tire and a race tire is way different though, so it's kind of defeating the purpose. It will still be lighter than a 195-205 on a 6.5"-7" wheel though. But if you're really worried about the weight then you'll want to spend the money on a real race tire.
Old Apr 16, 2012 | 06:04 PM
Jockobo's Avatar
my friend runs tires from a smart car. perfect fit
Old Apr 16, 2012 | 07:07 PM
MR.johnson's Avatar
lol whats the speed rating on those bad boys
Old Apr 16, 2012 | 07:10 PM
Oh wow lol more info on smart car tires?
does that say 145/65/15??
Old Apr 17, 2012 | 06:57 AM
SL0WEGG's Avatar
Yup
http://www.tirerack.com/tires/tires....rtnum=465TR5EC
Cheap compared to race tire, I'm curious as to how much it weighs
Old Apr 17, 2012 | 07:55 AM
MiamiVR6T's Avatar
Originally Posted by SL0WEGG
Yup
And a speed rating up to 118mph... Not good. Also weighs 12lbs.
Old Apr 17, 2012 | 04:24 PM
SL0WEGG's Avatar
okay for an all motor car
Old Apr 18, 2012 | 07:10 AM
redline_EF's Avatar
I've been using those Conti's for the past two months on the street and at the strip. For half the price of true skinnies and only 12lbs they work well. My car has a stock K20 and only traps 109mph, but I am working on a remote M90 supercharger setup. Even then if it traps 120-130, those 2-12 extra mph for a couple seconds will be fine.
Old Apr 19, 2012 | 10:24 AM
90dxhmt's Avatar
VX wheels [9lbs] and Walmart Nexen 155/80/13 which in Canada are under $50 a piece. They also make a 165/80/13 which is a little taller [23.5 vs 22.8 for 155's]. The speed rating of tires has a big safety factor and realistically is based on sustained speed not the 2-3 seconds at the end of the track you are actually beyond that rating.
Old Apr 23, 2012 | 07:54 AM
H22AFerio's Avatar
@redline_EF - what kind of wheels you have there for your skinnies? also are you rinning slicks on 16's in the front?
Old Apr 23, 2012 | 08:00 AM
guy_from_nerk's Avatar
Whats the real advantage of running rear skinnies? I have heard several things and just wanna weed out the bs. I've heard 1. They help stability and 2. They help pick up ET and MPH...whats true?
Old Apr 23, 2012 | 08:28 AM
H22AFerio's Avatar
Lighter wheel, Lighter tire cuz rubber is fawking heavy! that equals less Un sprung weight. less rotational mass that the car has to pull going down the track. You can pick up some speed and in turn will net you a lower time
Old Apr 23, 2012 | 08:33 AM
I figured that, I had heard claims of 4mph just by switching to the rear skinnies and .5+ taken off et's. Just wanna see if this is true before looking into buying a pair for my Integra
Old Apr 23, 2012 | 08:43 AM
H22AFerio's Avatar
Icon5 Re: Cheap skinnies?
haha well that may be possible but its hard to tell cuz everyone setup is different ya know? way to many variables to say "if you putt this skinnies on you will shave a full second off your 1/4!" haha but anything helps! getting rid of un sprung weight or any weight off your car helps I went for 11.7 to 11.5 just pulling out my back seat and my passenger seat.
d_EG COUPE
Mar 15, 2008 01:53 PM
JDM KING
Dec 15, 2006 07:25 AM
MarkV1184
Jun 4, 2005 12:04 AM
barry11j
Aug 3, 2004 04:40 PM
sleepin91teg
Mar 21, 2004 09:05 AM
