Engine oil overshooting drainpan
Old Apr 15, 2012 | 02:30 PM
regnevazota's Avatar
Icon2 Engine oil overshooting drainpan
The last time I did an oil change for a 94 Accord, the oil shot way past the drainpan that was positioned directly undeneath the drain-bolt. Got really messy to deal with, all over the garage floor. I guess it was the pressure exerted from the amount that had to go thru the small drain bolt opening. I dont have a vehicle lift to position one of those long telescoping drain funnels right up to the bolt hole. I use a floor jack. I'm wondering if I should start looking at some vacuum pump tools.
Any suggestions how to eliminate this? ...
Old Apr 15, 2012 | 03:53 PM
AccidentproWn's Avatar
Default Re: Engine oil overshooting drainpan
Get a longer drain pan. Hold the drain pan up while taking the plug out and position it as the oil drains. It's not rocket science.
Old Apr 15, 2012 | 05:33 PM
According to the threads in the archives, that is not needed. It seems that this overshoot is attributed to loss of vacuum from removing the oil cap. Supposedly if you leave the oil cap in place it doesn't happen ... ?
At any rate, I am seriously considering a vacuum pump of some kind.
Old Apr 16, 2012 | 05:40 AM
paintb91's Avatar
Could cut a 2 liter bottle in half using the top end as a funnels to just catch the oil and side stream it into a drain pan or just line up the drain pan 3 quarters past the drain hole..when it comes shooting out it'll be fine..or just use cat litter after each oil change to clean up the mess lol
Old Apr 16, 2012 | 06:14 AM
GhostAccord's Avatar
Am I dreaming? Is this a serious question?
Oil over shooting your oil drip pan sounds like a personal problem. Similar to pissing on the back of the toilet tank....
Next time move the pan (buy a quality drip pan) or keep the oil fill cover on the engine. Ether way a vacuum pump is not needed. You're over thinking a very trivial issue.
Old Apr 16, 2012 | 11:00 AM
Sounds like a practical idea, but I'm just getting too tired of struggling with every little thing. I think I'm gonna join the ranks of those who would rather switch than fight. Less messy and I wont have to worry about stripped pan threads.
Old Apr 16, 2012 | 11:11 AM
Originally Posted by GhostAccord
Am I dreaming? Is this a serious question? Oil over shooting your oil drip pan sounds like a personal problem. Similar to pissing on the back of the toilet tank.... . Next time move the pan (buy a quality drip pan) or keep the oil fill cover on the engine. Ether way a vacuum pump is not needed. You're over thinking a very trivial issue.
I understand your trying to help, but I wish I was dreaming. Christ, when it happened, I never expected it and I panicked and tried to put the drain bolt back in quickly, but there was so much force to the oil flow that it just started running down my arm into my shirt sleeve ... what a mess. I managed to move the pan back somewhat and then the flow suddenly changed again and undershot the pan -- murphys law ... I'm makin the switch.
Btw, are you suggesting that I close my mouth when I pee to avoid hitting the back of the toilet?
Old Apr 16, 2012 | 02:27 PM
CRX Si69's Avatar
A 5 gallon bucket does wonders.
Old Apr 16, 2012 | 03:35 PM
fubuallstar's Avatar
hahahaha sounds like someone doing their first oil change lmao
Old Apr 16, 2012 | 03:49 PM
JuggerNaut-CTR's Avatar
Sounds like operator error...never had a problem getting the oil in the pan.
You can pretty look at where its going to go once you take the pan bolt out. And if you need to scootch the pan over as it starts getting empty...then scoot it over.
Old Apr 16, 2012 | 07:09 PM
dglassmyer's Avatar
close thread
Old Apr 17, 2012 | 01:21 AM
holmesnmanny's Avatar
One of the earlier posters are correct. Just make sure you don't loosen the oil filler cap when changing the oil. It will help create suction that will keep the oil from coming out too fast, causing a splash of a mess.
Safety_Driver
10
Jan 16, 2012 12:45 PM
tjjm36m3
Jun 21, 2008 04:31 PM
pjr710
Jun 3, 2008 03:45 AM
tilhasbb
17
Aug 13, 2007 08:17 AM
prettyQuik
10
Jun 15, 2004 07:59 AM
