Oil and coolant mix on head gasket, cylinder and spark plug boot
Old Apr 15, 2012 | 11:05 AM
viking-101's Avatar
Default Oil and coolant mix on head gasket, cylinder and spark plug boot
Today i decided to check a couple of things on my b18b1 and see why it was running sluggish and i noticed there was oil and coolant on the spark plug boot, in the cylinder and on my head gasket. What could cause this by any chance?
Old Apr 15, 2012 | 11:12 AM
Dc4LsTeG's Avatar
EK9
Default Re: Oil and coolant mix on head gasket, cylinder and spark plug boot
Blown head gasket
Old Apr 15, 2012 | 11:31 AM
viking-101's Avatar
Thanks Dc4LSTeG I'm gonna have to buy another on hopefully soon. To be on the safe side is there a way to check and see if your head is cracked?
Old Apr 15, 2012 | 11:40 AM
Dc4LsTeG's Avatar
EK9
Youd have to take it to a machine shop and have them pressure test it.
Old Apr 15, 2012 | 12:11 PM
viking-101's Avatar
Another thing i notice was when i began to remove the head studs i remembered that i forgot to torque down the head studs and its a brand new head gasket on there too. Is there a way i can look at the gasket and tell its still good? and also what would be a good ft-lb to torque the factory head studs too?
Old Apr 15, 2012 | 12:36 PM
Dc4LsTeG's Avatar
EK9
No you can never reuse head gaskets
Old Apr 15, 2012 | 12:44 PM
91 EF DX's Avatar
You should also get new studs too. When u torque them they strech
Old Apr 15, 2012 | 04:34 PM
gesford's Avatar
but he didnt torque the head bolts, so you dont need new ones. but you do need a new gasket. and thats probably why that gasket blew, ALWAYS torque head bolts.
Old Apr 17, 2012 | 07:43 PM
viking-101's Avatar
Is it possible to reuse the head studs? I've heard there torque to yield studs and shoulb be replaced.
realis9
Aug 9, 2007 05:37 AM
JTCdudeman
Sep 29, 2005 05:42 AM
