quick timing-retard question
Old Oct 11, 2002 | 07:02 PM
keebler65's Avatar
Default quick timing-retard question
if i have to retard my timing with the addition of a supercharger, is this done by rotating the distributor cap or getting adjustable cam gears?
thanks
Old Oct 11, 2002 | 07:30 PM
moyerek's Avatar
Default Re: quick timing-retard question (keebler65)
rotating the distributor cap will accomplish your needed timing retard but it will be a constant timing retard no matter what boost you are running. adjustable cam gears will control you valve overlap, etc. not timing.
if you want to retard you timing in relationship to your boost you want to look into a MSD BTM spark control box. This will allow you to retard timing with relationship to boost. Accel also has a unit for Honda/Acura applications but I have not used/installed it yet.
Old Oct 13, 2002 | 05:17 PM
CivicEK.PDX's Avatar
Default Re: quick timing-retard question (moyerek)
By adjusting your cam gear (for intake if DOHC) your timing will change. Your cam controls the distributor.
Old Oct 13, 2002 | 07:24 PM
keebler65's Avatar
Default Re: quick timing-retard question (CivicEK.PDX)
but if i dont have adjustable cam gears, would the distributor work as well?
thanks!
CYBERCRXT
Dec 11, 2004 09:05 AM
has-t
Jul 1, 2003 09:58 AM
Mr.Integra
May 22, 2003 12:41 AM
Alias
Jan 28, 2003 06:56 PM
honda8882
Sep 29, 2002 11:28 AM
