1990 rt oil pan
According to the Helms, drain the engine oil, the transmission oil, drop the prop shaft (front to rear driveshaft), remove the transmission bash plate, remove the transfer case, remove the clutch cover, drop the oil pan.
You'll need to take apart that section of the transfer case (below). You don't have to drop half the motor.
It is a headache though. I've had to replace rt4wd oil pan before, it is rt4wd specific. Doesn't matter if automatic or manual, just make sure its rt4wd.
