Hesitation? obd2 b20
Old Apr 14, 2012 | 05:47 PM
JDMchristian991's Avatar
Default Hesitation? obd2 b20
This just started about a month ago,and i've exhausted my knowledge and getting fed up.
It is a 96 gsr with a 99 b20b with a p8r head.It has a rough idle,died in traffic/lights,and has a hesitation between what seems too be 2k-4k and only when 1/2 throttle or less.Anything above 1/2 throttle and it doesn't seem too do it.
I've replaced...
Plugs
Wires
Distributor cap
Rotor button
Fuel filter
o2 sensor
Ecu (with a known to be good p75)
Tps
Map sensor
What else could this possibly be?
Old Apr 14, 2012 | 06:45 PM
el crapitan's Avatar
Default Re: Hesitation? obd2 b20
have you checked the codes?
you're probably gonna wanna run a tune with that p8r
Old Apr 15, 2012 | 07:23 AM
No cel's.
It ran fine for near 2 years before this with just a p75.
Also,the miss seems to be getting worse.
Old Apr 15, 2012 | 11:12 AM
mouab18c1's Avatar
Check your ground wires?
Old Apr 15, 2012 | 11:41 AM
check valve lash. absolutely
Old Apr 16, 2012 | 11:56 AM
hondajdmb20b's Avatar
ok this might seem weird but it worked for me. unplug ur downstream o2 sensor and see if that works. mine was doing the exact samething at those same rpms and i tried that and it hasnt done it to me anymore in about a month now. lmk wat happens.
Old Apr 16, 2012 | 12:37 PM
Ej1k20aboy's Avatar
Do it
Old Apr 16, 2012 | 01:17 PM
do wat?
Old Apr 16, 2012 | 07:38 PM
that really won't tell you much
and it certainly doesn't solve the problem
Old Apr 17, 2012 | 02:50 PM
i was jus saying wat worked for me i know its weird but it worked.
Old Apr 17, 2012 | 04:01 PM
mouab18c1's Avatar
So you basically had a faulty sensor
Old Apr 17, 2012 | 05:48 PM
yea pretty much but that jus might not be the case for him. it may be stuck on limp mode also.
Old Apr 17, 2012 | 06:53 PM
The hesitation is solved.It was a few different issues,one of which was the o2.
Idle is still funky though,raises/lowers ect.
Also,i've already cleaned/replaced the iacv.
Old Apr 18, 2012 | 03:06 PM
yupp check ur tps or the map sensor.
Old Apr 19, 2012 | 04:34 AM
no, it's not weird. and no, it didn't "work". all unplugging the o2 does is keep the pcm in open loop. that is, ignoring all pcm inputs. that just indicates that there is a problem with a pcm input or the pcm's interpretation of the input
it does not indicate a faulty o2 sensor. although, it doesn't cancel it out either
Old Apr 19, 2012 | 04:17 PM
so how can i fix that problem. and i apologize not trying to thread jack
Old Apr 19, 2012 | 07:12 PM
did you check the codes prior to disconnecting the o2?
Old Apr 20, 2012 | 05:02 PM
not yet
Old Apr 20, 2012 | 08:02 PM
if you want to make an attempt at solving this, clear the pcm memory, reconnect the o2 and drive it for a few days. then check the codes
Palamala112
Apr 30, 2013 01:04 PM
blackouthx
13
Jul 23, 2007 04:01 AM
bizmackus
Feb 7, 2007 03:39 PM
civictunr_ls
Feb 23, 2005 03:19 AM
SleepnCiViC
18
Dec 8, 2003 08:51 AM
