crx with d16z6 with hf dizzy....but it messes up my timing..
Old Apr 14, 2012 | 10:31 AM
jcrredrex2012's Avatar
Default crx with d16z6 with hf dizzy....but it messes up my timing..
i have a crx 91 hf.. with d16z6 motor..hf harness/distributor and crx si computer...... it runs but messes up my timing.. i have a crx si distributor and z6 distributor ... a jumper harness.... which way should i go and whats left to to.... it runs ... but it sucks driving it like that... i dont got a p28 ecu.. but i do have a vtec contoller ... just to engage vtec..( i also have a jumber harness obd0 to obd1 ).. i bought this car like this... i just want to make it run like it needs to be... any graphs would help... or ways to do it
thanks
jesse
Old Apr 14, 2012 | 10:39 AM
Default Re: crx with d16z6 with hf dizzy....but it messes up my timing..
bump
Old Apr 14, 2012 | 10:40 AM
Mongo CRX's Avatar
I suggest you use the z6 distributor, and get a P28 ECU, then you will be running a stock z6 (I assume you are using the z6 intake manifold, etc.). I am not sure what sort of adapter harness you have. Places like www.rywire.com (and others) sell all the haness adapters you need, or you can make them yourself.
Old Apr 14, 2012 | 10:59 AM
hondawhat?'s Avatar
the best option would b to use the z6 dizzy and find a p28 ecu. next best option would b z6 dizzy and crx si ecu. you always want to match your dizzy to the engine. and match the obd of the ecu with the engine for best results. example- y8 would want a y8 dizzy and a obd2 ecu, d16a6 would b a6 dizzy and obd0 ecu, and so on. you get the picture.
Old Apr 15, 2012 | 01:39 AM
HotCheetos's Avatar
This ghetto but shave the tabs a bit, or ovalize the holes and fit it correctly so that your timing is "correct"
Old Apr 15, 2012 | 03:01 AM
213374U's Avatar
0x5359-0055
Community Builder
^ Dude, you need to go the **** away with your misinformation and post padding.
Here's the situation OP: You have a VTEC motor, possibly OBD-1, definitely MPFI, with a harness intended for a Non-VTEC carb'd motor, and a Non-VTEC distributor and ECU. Basically, you have big cluster**** on your hands likely "slapped together" by someone like Mr. HotCheetos above.
If I were in your situation, here's the list (in order) of what I would be doing:
1. Gather the correct parts
- A6 Dizzy
- OBD-1 VTEC ECU (P28)
- OBD-1 O2 Sensor
2. Check the wiring harness to ensure that the MPFI conversion was done correctly
- Search for a write-up on this, there are many out there
3. Ensure VTEC is wired properly (will have to add wires to your existing harness)
4. Install mentioned parts plus the jumper harness and verify timing
5. Fire it up and verify timing with a timing light
Welcome to H-T. You can learn anything and everything you might ever want to know about Hondas simply cruising around this site, reading, searching, and asking questions. Learn how to pick through the bullshit (reference post above this one), always double check the suggested method before wrenching, and don't let the trolls get the best of you. Oh yeah, proper grammar and articulate sentences/paragraphs go a LOOONNNNGGGG way around here. In any event, enjoy your stay.
Old Apr 15, 2012 | 05:41 PM
hondawhat?'s Avatar
- A6 Dizzy
but since he is running a Z6 engine wouldnt it b better to get a Z6 dizzy with 2 jumpers? the dizzy jumper and the ecu jumper. also it is a obd-1 engine, i dont think there was any other z6 that wasent obd 1. correct me if i wrong tho.
Old Apr 15, 2012 | 07:18 PM
yea thats was i was thinking too just get a p28 .. and get the 2 jumpers....look at this video... itz a full z6 swap..... i have p28 dizzy.. and jumper harness for it ... i just made a dizzy harness too obd0 to obd1.... .... can i run full z6 with no p28 .. and using the pm6.. should it even start ... cuz i tried and it turn on, then off. it doesnt pass 2rpm.... i forgot to let everyone thats it has high compression pistons...........so i need all that help i can get..... heres a video with it running off the pm6.....it throws code 16 http://www.youtube.com/watch?v=GmGWb...9rcJNON1UOxuY=
Old Apr 16, 2012 | 05:06 AM
213374U's Avatar
0x5359-0055
Community Builder
Originally Posted by jcrredrex2012
it throws code 16
Fuel injection? You sure your timing is off and that it's not just a cylinder or more misfiring?
Old Apr 20, 2012 | 07:00 PM
hondawhat?'s Avatar
hate to agree with hotCheetos but the hf is mpfi, not carb. And as far as the claim to ls dizzy and pm6, he probably just mis timed it and got lucky or something. a tooth off on cam timing and a few degrees off on the dizzy can do some weird stuff. but anyways back to the problem. it is starting to sound like a misfire, not a timing issue. use a p28, z6 dizzy and nessacery jumpers, verify timing. once that is done run a spark test and make sure your spark plugs are good. if all good there go to fuel delivery. clogged fuel filter, or injectors. low fuel pressure. also look at the air intake, clean air filter?
CivicSD
Sep 28, 2010 10:57 AM
hurleyint1386
Apr 9, 2006 04:20 PM
kgard
Nov 5, 2005 12:40 AM
Sirex
Apr 25, 2003 10:37 PM
Sirex
Apr 24, 2003 09:12 PM
