Lighting HID/Xenon kits, Retrofits and Associated Topics
HALO HEADLIGHTS/ OVERHAUL AND MASTER REBUILD KIT
Old Apr 14, 2012 | 03:02 AM
FOKAI95's Avatar
Icon2 HALO HEADLIGHTS/ OVERHAUL AND MASTER REBUILD KIT
HEY GUYS IM NEW TO THE HONDA SCENE AND I ORDERED ME A HALO HEADLIGHT FOR MY 95 HONDA CIVIC I INSTALLED THE LIGHT AND THEY WORK FINE I WAS JUST WONDERING ARE THE HALOS SUPPOSE TOBLING WHEN SIGNALING LMK THANKS....
ALSO DOES ANYONE KNOW WHERE I CAN ORDER A MASTER REBUILD KIT OR A OVERHAUL KIT FOR A 92-95 HONDA CIVIC D15B7 SOHC LMK THANKS AGAIN..
Old Apr 14, 2012 | 03:04 AM
grumblemarc's Avatar
The Grumpiest
Default Re: HALO HEADLIGHTS/ OVERHAUL AND MASTER REBUILD KIT
Why are you typing in all caps? Read this.
http://kathrynvercillo.hubpages.com/hub/What-People-Think-When-You-Type-in-All-Caps
Halos "ugh" are NOT supposed to blink unless you wired them that way. They are a detail ripped off from BMWs. Those do not blink.
Try Ebay for your rebuild kit. It would be better for you if you just got a replacement JDM engine.
Old Apr 14, 2012 | 04:11 AM
FOKAI95's Avatar
sorry bout that btw i tried ebay no luck and i dont got that type of money to get a replacement motor anywhere else i can look btw im in guam..
Old Apr 14, 2012 | 08:11 AM
gzes's Avatar
Yea when i wired the halos on my Tahoe I first wired them to turn signals and didn't like em so just sealed wires. If its the same then there should be 3 wires, 1 is ground one is constant power when parking lights on and one that works as turn signal so just swap the wire to parking wire and should be good. And yes my Tahoe Has Halos lol
Old Apr 14, 2012 | 12:01 PM
TriniSpeC's Avatar
I would say look for used components on eBay since money is a issue, but theres no guarantee with used parts
Old Apr 15, 2012 | 12:22 AM
FOKAI95's Avatar
i did wire the halos to the constant power in the parking light and when i signal it signals too i tried both wires on the parking light and the way i hooked it up it made the halos constant but although when i signal it blinks to
Old Apr 15, 2012 | 06:15 AM
gzes's Avatar
Maybe both wires are touching causing them both to do that. Try going back and look to see if they are bare and if so tape it up and try again because one shohld always be constant power and the other should always turn on and off with the turn signals
Dwood12
11
Aug 18, 2014 09:41 AM
FOKAI95
Apr 23, 2012 01:30 AM
AWDManiac
Oct 15, 2011 11:23 PM
Smokinsax
Feb 25, 2005 11:32 PM
HondaRacer32
Jan 29, 2004 03:34 PM
