Lighting HID/Xenon kits, Retrofits and Associated Topics
Looking for a good projector headlight
Old Mar 16, 2012 | 09:30 PM
EgInvy's Avatar
Default Looking for a good projector headlight
I have a 1993 civic hatchback vx and I'm in the market for some projectors that are the OEM size. I hate the way the headlight with the attached blinker look!
I have an HID kit hooked up already. It's bright, but it doesn't illuminate that far in front of my car. This is what i'm looking for. If you know anything about these let me know or if you have any others in mind I would appreciate the help!
http://www.andysautosport.com/honda/...o00062867.html
Old Mar 18, 2012 | 06:47 AM
Joon Joon's Avatar
Default Re: Looking for a good projector headlight
aftermarket projectors arent meant for hids and dont have good output.. if you want output, do a retrofit..
Old Mar 20, 2012 | 07:18 PM
EgInvy's Avatar
I want the light more focused towered the road. With the oem headlight the light is shining really high up.
I'll have to do some research on retrofit headlights. Do you have any links that could help?
Old Mar 20, 2012 | 07:35 PM
Joon Joon's Avatar
hidplanet.. you dont want your lights shining up high, then youll blind people.. a retro will help shine down the road further without having to aim them high..
Old Mar 21, 2012 | 11:52 AM
EGRhatch's Avatar
RETRO... INFACT if you dont have the skill, ^^^^ can probably do one for you,
there was also someone on here selling a complete retro with tsx projectors (which i believe are bixenon) so then you get the > OEM output and hi beams i think last i saw he wanted $350.
look at spending close to if not more than that any way you do it other than a cheap HID kit which will only make your situation worse
Old Mar 21, 2012 | 12:13 PM
Joon Joon's Avatar
tsx arent bixenon..
Old Mar 22, 2012 | 10:41 AM
Try2Live4God's Avatar
I believe the 04-05 TSX projectors are bi-xenon.
Old Mar 22, 2012 | 11:33 AM
Joon Joon's Avatar
no single xenon..
Old Mar 22, 2012 | 03:56 PM
EgInvy's Avatar
I've been doing research on it, but I still don't know much about retro fitting. The oem headlights don't have clear licences so it doesn't work to well with the retro projectors. I was thinking about trying it, but I need to find a cheap pair of oem headlights. Also what's wrong with my link? They look like a pre-made retro fit headlight...
Old Mar 22, 2012 | 04:40 PM
EgInvy's Avatar
This is the HID kit that I have. Ill this work with a retrofit?
http://imageshack.us/f/834/img20120322171336.jpg
Old Mar 22, 2012 | 07:17 PM
Joon Joon's Avatar
they arent premade retros.. those are halogen projectors which arent made for hids.. quality on them arent great.. you need clear lenses ebay housings or send out the stock lenses to get sanded down on a machine.. yes you can use those ballasts
Old Mar 23, 2012 | 07:10 PM
EgInvy's Avatar
I guess i'm going to get CTR headlights and see how they work. If it's still the same I'll be doing a retrofit. Thanks for your help! It was very useful
Old Mar 23, 2012 | 07:42 PM
Joon Joon's Avatar
ctr headlights? theres no ctr for egs..
Old Mar 23, 2012 | 11:20 PM
EgInvy's Avatar
well the JDM black housing headlights http://www.jdmshit.com/parts/headlig...dlight_BLK.jpg
Old Mar 24, 2012 | 06:13 AM
Joon Joon's Avatar
sorry again those arent jdm... they just name them that.. i just call them clear housings or ebay clear housings because thats pretty much what they are.. those would be best to do a retro in..
Old Mar 24, 2012 | 10:43 AM
EgInvy's Avatar
okay I thought so... This person is selling some headlights on craigslist that look the same as my lastlink. I want to get them but I don't want to buy crap housing. Are there real JDM headlights out there or are they all just black housing ebay headlights? Also is $100 too much?
http://modesto.craigslist.org/pts/2917276570.html
Old Mar 24, 2012 | 11:54 AM
Joon Joon's Avatar
real jdm ones are like us spec ones but plastic and doesnt have the nipples on the lens.. 100 isnt bad for new ones.. use them to do a retrofit..
Old Mar 28, 2012 | 09:40 AM
Saggio's Avatar
I'm doing a retro this week. I'll post pics when I can.
Here are a few pics of my progress...
Cut out upper area to make room for projector shroud:
Installed projector and shroud:
Both headlights done, just need to install glass:
Will update when installed.
Old Mar 31, 2012 | 06:18 PM
EgInvy's Avatar
oh awesome! Thanks Saggio! I can't wait to see the finish product! Are those spec-D headlights?
Old Apr 4, 2012 | 08:28 AM
Saggio's Avatar
Complete:
Old Apr 4, 2012 | 08:54 PM
EgInvy's Avatar
wow, that looks like Christmas :D What projectors are those and did you test where they were pointing before you sealed them or did you just eyeball it?
Old Apr 5, 2012 | 02:36 AM
0zker's Avatar
My headlight retro isn't as good as Saggio's. Going to redo my headlights with some FX-R's and shrouds. but check out my fog lights. Blazer projectors from TRS with 6000k's but going down to 4200k. that pic is just the fog lights aimed at a bright parking lot wall. car was on an incline just to show the razor sharp cutoff.
Old Apr 5, 2012 | 06:36 AM
Saggio's Avatar
Morimoto Projectors with 55w 5000K DS2 bulbs
E46 Shrouds
I didn't check anything as far as light before sealing them back together. Took 5 minutes to aim them correctly.
Ozker: I want to do fogs now after seeing yours!
Old Apr 8, 2012 | 04:20 AM
Outrun's Avatar
Try aiming your headlights first.
Old Apr 11, 2012 | 08:15 PM
EgInvy's Avatar
I'm going to try but when I have the chance. I need to get a new exhaust manifold right now. Mine is cracked So i'm putting all my time into trying to find another one...
