Boosting a DC with B16A2: What sensor plugs are these? *PICS* and PS Removal!!
Old Apr 13, 2012 | 05:36 PM
Arthas's Avatar
Icon6 Boosting a DC with B16A2: What sensor plugs are these? *PICS* and PS Removal!!
Sup all
1995 Integra RS
B16A2 swap
My friend got this DC4 with the B16A2 already swapped in. The swap was pretty much slapped together and the VTEC isnt wired properly. Im pretty sure they re used the original RS harness and just added the VTEC plugs since it still has OBD1 injector clips. Ill fix that during the turbo install but it has a few empty plugs.
The first one is on the injector harness and it has like 3" of slack wire. The second one is behind the intake manifold and it has the exact same clip.
EDIT: Its the round style IAT. Thanks HondaPartsHero.
[IMG]http://img.photobucket.com/albums/v356/eclipse6000/imagejpeg_2_9.jpg[IMG]
[IMG]http://img.photobucket.com/albums/v356/eclipse6000/IMAG0681.jpg[IMG]
[IMG]http://img.photobucket.com/albums/v356/eclipse6000/IMAG0686.jpg[IMG]
Second missing plug
We added that solenoid thingy from a Prelude, but prior to that it was missing. Is it hooked up correctly? The line at the bottom is going to the EVAP canister and the line at the top goes to the intake manifold.
_______________
Last, we are removing the Power Steering. How do we loop it or remove all the lines? The line that goes from the rack to the pump is leaking. If we're there might as well take it off LOL.
edit: http://www.team-integra.net/forum/19...l-meltman.html
Thanks in advance!!!
Old Apr 13, 2012 | 06:31 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Boosting a DC with B16A2: What sensor plugs are these? *PICS* and PS Removal!!
First pic is for the intake air temp sensor. Since the A2 had it in the intake arm the manifold doesn't have a spot for it. You can use the round style IAT from any OBD1 Honda and put in the intake arm
Second plug is EVAP purge. You can plug it into the EVAP purge or leave it dangling it won't throw a CEL. You have the vacuum lines backwards on it.
From what I've read loop it.
Old Apr 13, 2012 | 06:42 PM
Arthas's Avatar
Thanks for your prompt response
I figured it was for the IAT but I tried one from my EK and it didnt fit. Do EG's and MPFI EF's have the IAT that mounts to the intake manifold? Ill try and find one at the junk yard tomorrow. The car is going to be boosted though, where would be the best place to mount it? I had it dangling on my EK before and after boost and I never threw a MIL.
So just loop the lines on the EVAP purge, or on the canister so it doesnt throw a MIL? Ill flip the lines over tomorrow, reset the battery and try to see what MIL's it has after.
jvaughn
12
Jan 20, 2008 05:01 PM
jdmguy1221
Jul 13, 2005 09:32 AM
jaidedeye
10
Jun 16, 2005 06:32 AM
gsrhatch530
Mar 31, 2004 09:09 AM
