RD TECH P28-SPEC-A02 ECU $140.00 Retail: $199.00
$140.00 OBO...
txt: 619-665-0591
Honda P28 ECU
This is the most versatile ecu. It come from a 92-98 Honda Civic EX or SI model. It can be used to run any h, b, or d series motor with the right wiring harness and distributor. This ECU is chipped and ready to go. This ecu has the ability to run Vtec motors. It comes with a blank chip or a base map.
Comes with:
1. P28 ECU or a P28 Equivalent ECU
2. OBD1 Chip kit installed
3. SST27SF512(Blank or Pre programmed base map)
txt: 619-665-0591
Honda P28 ECU
Comes with:
