DA vacuume line for MAP sensor?
Old Apr 13, 2012 | 09:08 AM
Charlie Moua's Avatar
Default DA vacuume line for MAP sensor?
I know DA (90-93 integra) has the MAP sensor located on the firewall.
I wanted to know why the there is a "T" vacume fitting on the bottom of the map sensor when 1 line leads to a blocked WHITE plug & the the other side of the T fitting is where the vacuume source is from (leads to IM brass plug)?
1) couldn't i just run vacuum line from IM direct to MAP sensor?
2) why did honda even make an extra T fitting line for the MAP vacuum anyways? is it suppose to reduce PSI the MAP sensor will see ?
Old Apr 13, 2012 | 11:38 AM
fcm's Avatar
fcm
Old Fart
Default Re: DA vacuume line for MAP sensor?
MM&Y of car would help, "DA" is not a lot of help. 94
Old Apr 13, 2012 | 08:24 PM
fixed it...
tony_2018
May 25, 2014 06:48 PM
getupoffthatthan
Oct 15, 2008 03:20 PM
90b20vteckidd
17
Sep 27, 2006 06:03 PM
92hybridAccord
May 4, 2004 11:34 AM
