B-Series, Turbo Stuff, Head Bolts, Pistons, Rods and MORE! RANDOM B-Series Civic Stuf
Old Apr 12, 2012 | 02:36 PM
MoreCowbell's Avatar
Default B-Series, Turbo Stuff, Head Bolts, Pistons, Rods and MORE! RANDOM B-Series Civic Stuf
Pickup in Lancaster, CA. Prices are Firm and for Picked up.
Also anything under $20 bucks I wont bother meeting with someone for so if you see something cheap you like, see anything else I'm selling to make it worth my time.
Brand new ACL Race Main Bearings (Applications shown on the box) $50
GSR Head Bolts taken out of a perfectly running 78k mile motor $30
GSR Pistons and rods taken out of a perfectly running 78k mile motor $40
Complete JDM B20Z Head (valve cover slightly damaged where the gear cover is, if you plan on using cam gears you can cut it off nicely) $120
3" TBolt and robber clamp $5.00
I believe its a RSX shift ****.. Was on my car when I first got it. $5.00
38mm Wastegate Springs 3 and 4 psi $20
B Series throttle body spacer $20
Turbo Oil Drain Fittings $20
Denso Stock Map Sensor for Bseries and possibly d-series $20
Stud Finder $5.00
Radiator Overflow cap snap on type (not a typical fitment) $5.00
Top Radiator mount for Civic $5.00
Flange and Tip for Wastegate $5.00
Oil Fittings. I think I have two 4an ones there one having a home made restrictor on it. $5.00
Stock air box for honda Crv $15
Stock O2 Sensor from my civic $25
GSR Fuel Rail $15
Wastegate dumptube $10
1 1/2 inch clamp for dumptube flex type of piping. $5
Radiator cap honda/acura $3.00
Resistor Box, cleaned and painted high temp resistant. $20
T3/T4 turbo blanket (never used) $30
Old Apr 12, 2012 | 02:58 PM
Dc4LsTeG's Avatar
EK9
Default Re: B-Series, Turbo Stuff, Head Bolts, Pistons, Rods and MORE! RANDOM B-Series Civic
Bump
Old Apr 12, 2012 | 03:17 PM
EG9b20vtec's Avatar
Bump
Old Apr 14, 2012 | 07:17 PM
THanks
Old Apr 15, 2012 | 07:52 PM
Bump
Old Apr 19, 2012 | 03:20 PM
I also have ARP Main Studs to add to the list for B18 and B16. Will have pics up soon. Never installed, $50 Shipped.
Old Apr 19, 2012 | 04:17 PM
harms_is_back's Avatar
Have Injectors
Old May 1, 2012 | 08:55 PM
AirBox and Oil Drain Fittings sold.
GSR Oil pan thats tapped for turbo. $60 Picked up
China Blowoff valve.. $15 picked up
Old May 1, 2012 | 08:57 PM
Originally Posted by harms_is_back
Have Injectors
Not anymore. Sold them way back on here
Old May 2, 2012 | 08:22 AM
Ttt
Old May 2, 2012 | 04:06 PM
top
Old May 4, 2012 | 08:39 AM
Top
Old May 5, 2012 | 09:42 PM
bump
Old May 6, 2012 | 03:44 PM
BoostedDOHCGSR's Avatar
10 Year Member
Hit me up Might size up the turbo blanket and might pickup the china bov
Old May 9, 2012 | 07:55 PM
01oemTeggy's Avatar
Still have the acl bearings?
Old Jul 23, 2012 | 04:43 PM
Yes I have not tried to sell anything since. Still have almost everything
yes
T9U4ReBgO
May 13, 2010 01:56 PM
blacK_Dc4
Northern California (Sales)
60
Apr 25, 2007 03:47 PM
swartz
May 14, 2005 11:11 AM
94delsol
Dec 7, 2004 05:58 PM
