Need Advice / Information On Getting A New Motor
So I recently purchased a 2001 Integra LS from Craigslist and to make a long story short the motor ended up being junk so now I am getting ready to replace it. I Have about 2000.00 to spend so I am trying to decide the best route to go. I am looking at either dropping in another b18b1 I can get shipped for about 1100.00 or picking up just a b16 motor. If I went with the B16 would I be able to keep and use my motor mounts, shift linkage , wiring harness and transmission ? I am thinking I will just need the ecu, wire up vtec and maybe axles ? Am I missing anything here ? Also I would upgrade to a better transmission later this year. In the long run I want to build an all motor set up that I can drive daily. Please give me some advice on which set up and any thing I might have left off. Thanks
B20B/B20Z
Displacement: 1,973 cc (120.4 cu in)
Power: 147 hp (110 kW) @ 6200 rpm
Torque: 133 lb·ft (180 N·m) @ 4800 rpm
Rod length: 137 mm (5.4 in)
Compression: 9.6:1
Bore: 84 mm (3.3 in)
Stroke: 89 mm (3.5 in)
Redline: 6900 rpm
B18B1
Displacement: 1,834 cc (111.9 cu in)
Compression: 9.2:1
Bore: 81 mm (3.2 in)
Rod Length: 137.01 mm (5.394")
Rod/Stroke Ratio: 1.54
Power: 145 hp (108 kW) @ 5800 rpm & 130 lb·ft (176 N·m) @ 5200 rpm
Redline: 6800 rpm (7200 rpm on JDM Domani)
Rev Limit: 7200 rpm
Compression: 9.6:1
Redline: 6900 rpm
B18B1
Compression: 9.2:1
Rev Limit: 7200 rpm
Either, my buddy has a b20b in his crx and that thing rips with just minor boltons and a tune. Later on if you want more power you can do a crvtec with a b16/gsr head and supporting mods or boost, up to you. They are great motors.
HondaTeKnology
54
Jan 4, 2008 08:16 PM
DRAG14ciVHBKSI
Aug 8, 2002 11:00 AM
