remote starter
1991 Acura legend
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white |+ |ign harness or fusebox |
| STARTER|black/white |+ |ign harness or fusebox |
| IGNITION|black/yellow |+ |ign harness or fusebox |
| ACCESSORY|yellow |+ |ign harness or fusebox |
| POWER LOCK|green/white |- |door lock module above |
| POWER UNLOCK|green/red |- |accelerator pedal *2 |
| PARKING LIGHTS +|red/black | |dr. kick panel/fusebox |
| PARKING LIGHTS -|red/green | |at steering column |
| HEADLIGHTS|blue to blue/red |- |steering column |
| DOOR TRIGGER|wht/blk or blk/wht |- |plug above dr. kick |
| TRUNK/HATCH PIN|green/black |- |plug back of cluster |
| HOOD PIN|yellow/red |- |at anti-theft module |
|TRNK/HTCH RELEASE|white/black |+ |dr. kick/rear harness |
| FCTRY ALARM ARM|green/yellow |- |at anti-theft module |
|FCTRY ALRM DISARM|green/red |- |at anti-theft module |
| TACHOMETER|blue/silver dots | |back of dash or *1 |
| BRAKE WIRE|green/white |+ |brake pedal switch |
| HORN TRIGGER|blue/red |- |steering column |
| LF WINDOW UP/DN|red/blu - red/yel |A |in drivers door |
| RF WINDOW UP/DN|blu/yel - blu/grn |A |in drivers door or dkp |
| LR WINDOW UP/DN|grn/yel - green |A |in drivers door or dkp |
| RR WINDOW UP/DN|yellow - yel/grn |A |in drivers door or dkp |
| RADIO 12V|white/yellow |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/red |+ |radio |
| RADIO ILLUMINATE|red/black |+ |radio |
| POWER ANTENNA|yellow/white |+ |radio |
| LF SPEAKER|blu/grn - gry/blk | |radio |
| RF SPEAKER|red/grn - brn/blk | |radio |
| LR SPEAKER|blu/yel - gry/wht | |radio |
| RR SPEAKER|red/yel - brn/wht | |radio |
Notes:
*1 Tach wire located at 12-pin green plug at back of instrument cluster,or at tach test connector by passenger side shock tower - single wire w/plug *2 Door lock module and factory anti-theft mounted together between column and center console - can also use black/white and black/red here for locks.
Notes:
1988 Acura Legend
| 12V|wht/blk and white |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| SECOND IGNITION|yellow |+ |ignition harness |
| ACCESSORY|blue/white |+ |ignition harness |
| SECOND ACCESSORY|white/red |+ |ignition harness |
| POWER LOCK|green/white |- |lock module left of |
| POWER UNLOCK|green/red |- |steering column *1 |
| PARKING LIGHTS +|red/black | |steering column |
| HEADLIGHTS|blue/red |- |steering column |
| DOOR TRIGGER|black/white |- |instrument cluster harness |
| TRUNK/HATCH PIN|blue/green |- |security module *2 |
| HOOD PIN|yellow/red |- |security module *2 |
|TRNK/HTCH RELEASE|white/black |+ |trunk release switch or DKP |
| FCTRY ALARM ARM|green/white |- |security module *2 |
|FCTRY ALRM DISARM|green/red |- |security module *2 |
| TACHOMETER|blue | |ignition coil |
| SPEED SENSE|yellow/red | |instrument cluster |
| BRAKE WIRE|green/white |+ |brake switch |
| HORN TRIGGER|blue/red |- |column or security mod |
| WIPERS|blu/red & blu/grn |- |steering column |
| LF WINDOW UP/DN|blk/yel - blk/grn |A |drivers door switch |
| RF WINDOW UP/DN|blu/grn - blu/yel |A |in drivers door or dkp |
| LR WINDOW UP/DN|green - grn/yel |A |in drivers door or dkp |
| RR WINDOW UP/DN|yel/grn - yellow |A |in drivers door or dkp |
| SUN RF OPN/CLOSE|grn/red - grn/yel |A |sun roof relays |
Notes:
*1 The lock module is mounted on the rear drivers side of a relay center located between the steering column and drivers kick panel. To access the lock module, unbolt the relay center and drop down. *2 The security module is located under the drivers front seat on the 2 dr, and it is in the trunk behind the left rear seat on the 4dr.
Notes:
TwoFaced
Dec 16, 2010 05:34 PM
