jdm itr header heat shield bolt size/pitch????
Old Apr 10, 2012 | 11:40 PM
saemoonyang's Avatar
Default jdm itr header heat shield bolt size/pitch????
I've searched and cant find a answer, just hearing people saying 12, 14, 8.
I looked up on acura site for the usdm itr and they say its a 8x14 bolt but that dont fit either because I grabbed some from the hardware store.
Anyone?
Old Apr 12, 2012 | 04:58 PM
safedriver's Avatar
Default Re: jdm itr header heat shield bolt size/pitch????
Go to Fastenal. They have a great selection of metric hardware. I would guess that the pitch is 1.25
Old Apr 13, 2012 | 05:23 AM
Dave_B's Avatar
Def a 12mm bolt.
Pitch unsure. Just looked at mine last night.
Old Apr 13, 2012 | 02:45 PM
HeikDiesel's Avatar
99% sure its a M8-1.25x14mm bolt. You'll probably have to get a 15 or 20mm though
Old Apr 13, 2012 | 05:23 PM
It wouldn't budge and i didn't want to force it incased it ruined the thread. I can try again.
Thanks
Old Apr 13, 2012 | 05:46 PM
HeikDiesel's Avatar
Are you sure the pitch of the bolt that you bought is a 1.25?
Old Apr 13, 2012 | 09:06 PM
racebum's Avatar
are you sure they are different than usdm?
i never compared the two
Old Apr 13, 2012 | 10:42 PM
S2kRyan's Avatar
Automotive bolts are metric fine thread. Make sure you pay attention to that when sourcing. Your basic hardware store will probably not supply those. As stated you should be looking for an M8-1.25. The diameter of the bolt is not determined by what size socket fits the hex head... Wurth is a great supplier of automotive fasteners as well. Ex- Fastenal manager here :D
Old Apr 14, 2012 | 04:20 PM
safedriver's Avatar
Thanks
Before it will strip, it will rip the aluminum heat shield (the nut side).
I have a couple of new in their plastic heat shields, which I never installed. My rattle was a gut-busted cat and I wasted my change on the shields.
Old Apr 17, 2012 | 08:18 PM
COLIMA0003ITR's Avatar
ill check mines
Old Apr 18, 2012 | 03:12 AM
GearHeadDeals.com's Avatar
I also think it's going to be an M8-1.25
Old May 8, 2012 | 05:22 PM
PaulMc's Avatar
Painfully Stupid
Will the JDM ITR heat shield work on a JDM ITR header in a USDM ITR? Stupid question but want to double check before i purchase. Thanks
Old May 10, 2012 | 03:17 PM
JDM CTR '00's Avatar
Yes
Old May 10, 2012 | 06:02 PM
PaulMc's Avatar
Painfully Stupid
Originally Posted by JDM CTR '00
Yes
Thanks.
si0385.
Dec 12, 2016 03:23 PM
alpinegroove
Nov 18, 2013 01:27 PM
dan89crxsi
24
May 18, 2008 10:25 AM
MidShipCivic
Welding / Fabrication
Nov 30, 2006 11:35 PM
DC2 to AP2
Acura TL, RL & ZDX
Nov 19, 2005 06:37 PM
