i have a ZC?!?!
Old Oct 11, 2002 | 04:16 PM
Creepshow S60's Avatar
Default i have a ZC?!?!
hi everyone. i don't know too much about cars, but have been learning for the last 3 or 4 years. anyways, i got a crx about a year ago. the guy before me said that the original engine was removed (because it was damaged...he didn't specify how). he said that a newer crx si (d16a6 correct?) was swaped into place on my car. i just cleaned the engine bay today. i thought it was pretty funny that the engine bay was so dirty that i couldn't even see the engine code stamped on the block. i took a rag and started wiping. it didn't say d16a6....it said ZC. ZC? correct me if i'm wrong, but isn't this a dohc 130hp motor from japan? are there sohc zcs too? i don't really know anything about the ZC, besides hearing about how they are cheap motors and lots of people put them in crxs. any information/comments would be nice. thanks!
Old Oct 11, 2002 | 04:19 PM
my_slow_civic's Avatar
Default Re: i have a ZC?!?! (sieker)
Yeah, you have the SOHC ZC.
Old Oct 11, 2002 | 04:38 PM
how do you tell the difference between a sohc zc and a dohc zc? is it somthing as simple as it saying "dohc" on the valve cover?
Old Oct 11, 2002 | 04:44 PM
MrTodd's Avatar
It has two cams obviously. The upper timing belt cover will house two big cam gears. The DOHC model's valve cover has the spark plug holes right down the center.
Old Oct 11, 2002 | 05:05 PM
blacksoul's Avatar
If you have a doch zc, you wont have a timing belt cover unless you have an aftermarket hood.
I think the sohc Zc's had brown valve covers?
Old Oct 11, 2002 | 09:50 PM
AudioXtremes's Avatar
Default Re: i have a ZC?!?! (blacksoul)
well my dohc zc fit under my usdm stock hood with timing cover. also the sohc valve cover isn't brown your thinking of the older zc.
Old Oct 12, 2002 | 12:56 AM
[626]phixionEF91's Avatar
i have a sohc zc.
the valve cover is black, not brown. brown covers came on the usdm dohc zc - 119 hp.
the jdm sohc zc, from what i have researched has 120 hp, and has a black valve cover. the way you can tell the difference is the stamp on the block, (obviously) and the cam gear cover has all sorts of stuff written in japanese on it
Old Oct 12, 2002 | 06:43 PM
Charlie Moua's Avatar
Default Re: i have a ZC?!?! ([626]phixionEF91)
Yes.... i didn;t belive it my self until this moring when i went to go test drive a 90si with the SOHC ZC.
---------I though the guy was BS'in but it really was a zc..... What is the differece between that and my USDM D16a1?
**** gotta say this thing has some good torqe for a 1.6 man.... still can't belive it.
****WHAT MAKES IT MORE powerful than the D16a?
****can't you just get a ZC BLOCK and use a D16a head?
Old Oct 12, 2002 | 07:27 PM
chief_rucka's Avatar
Default Re: i have a ZC?!?! (Charlie)
i now know i have a SOHC ZC now! thanks to all HT'ers who helped me with info on what my engine was. my dad bought a 1989 CRX SI for $2150 w/ 45k on the engine. here the link to the pic of my engine: http://www.imagestation.com/picture/...c/fd579a7b.jpg
[Modified by E30rider, 8:30 PM 10/12/2002]
[Modified by E30rider, 8:37 PM 10/12/2002]
[Modified by E30rider, 8:39 PM 10/12/2002]
Old Oct 12, 2002 | 07:28 PM
Aphrodavid's Avatar
youre refering to the d16a1(1st gen teg) which is NOT the same thing as a ZC. d16a1 is basically a ZC motor with lower compression. no such thing as a USDM ZC.
Old Oct 12, 2002 | 07:41 PM
altoid's Avatar
Default Re: i have a ZC?!?! (DX-R)
i have a sohc zc, its pretty much the jap spec version of the a6
Old Oct 12, 2002 | 10:44 PM
Superhatch's Avatar
Default Re: i have a ZC?!?! (altoid)
Yeah oddly enough Im swapping my old si engine into my new si (old one has a B18b now). I always assumed it was a D16a6 so I never really looked...but hey what do you know it was a soch zc! I've been searching the web for more info...searched here...searched the d series website. Really havent found any solid info such as comp. ratio. hp. tq. If I find anything, or if anyone else does [Ill] post back here..
-Jake
Old Oct 12, 2002 | 11:23 PM
LoooseGSR's Avatar
Default Re: i have a ZC?!?! (SuperHatch)
I don't get it, the engine in that pic looks exactly like the one in my 89 CRX Si, and I have never looked at the block...sooooo....is mine a SOHC ZC too?
Old Oct 17, 2003 | 12:21 PM
BAZ's Avatar
BAZ
Default Re: i have a ZC?!?! (PSUCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PSUCRX &raquo;</TD></TR><TR><TD CLASS="quote">I don't get it, the engine in that pic looks exactly like the one in my 89 CRX Si, and I have never looked at the block...sooooo....is mine a SOHC ZC too?</TD></TR></TABLE>
Look at the stamp on the block. If it says d16a6 you have the stock USDM sohc Si motor. If it says ZC obviously you have the JDM motor.
Old Oct 17, 2003 | 03:51 PM
Outsane's Avatar
Default Re: i have a ZC?!?! (BAZ)
the single cam ZC has domed pistons...
At least thats the word on the street...
and the Intake manifold is slightly bigger
some of the SOHC ZC's are carbed, Singgle cam ZC heads that are carbed have a hole in the back of the block on the distro side. The cam has 17 lobes, 16 for valves and one more for a fuel pump.
Old Oct 17, 2003 | 03:54 PM
Sonny's Avatar
Default Re: i have a ZC?!?! (SiR Hizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Hizzle &raquo;</TD></TR><TR><TD CLASS="quote">
youre refering to the d16a1(1st gen teg) which is NOT the same thing as a ZC. d16a1 is basically a ZC motor with lower compression. no such thing as a USDM ZC.</TD></TR></TABLE>
The USDM D16A1 came in 2 versions. The 86-87 motor made 113 hp and has a brown valve cover. The 88-89 motor made 118 hp and has a black valve cover. I'm using a hybrid of the 2 engines in my 87 CRX Si.
The 88-89 USDM D16A1 and 88-91 JDM ZC also have the same compression. They both use the same pistons (PM7). See my sig for details.
Sonny
Old Oct 17, 2003 | 04:25 PM
Outsane's Avatar
Default Re: i have a ZC?!?! (Sonny)
I thought the SOHC ZC pistons..
not the dual cam..but I could be wrong..
do you have a link to the carland microfische you were on..?
Old Oct 17, 2003 | 08:18 PM
LoooseGSR's Avatar
Holy *****...I never wrote that....I'm not that stupid...I've known mine was an A6 since I got it...still love it though
Old Oct 17, 2003 | 11:31 PM
dingusjt's Avatar
lets not forgot about the sohc zc cam which is pretty much the only difference between it and the d16a6..
damn i'm inspired, i want to go check on my car and see whats under the hood....damn still d15b2
Old Oct 18, 2003 | 07:37 AM
Mrock's Avatar
Default Re: i have a ZC?!?! (dingusjt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dingusjt &raquo;</TD></TR><TR><TD CLASS="quote">
damn i'm inspired, i want to go check on my car and see whats under the hood....damn still d15b2 </TD></TR></TABLE>
Nice. You get my "best post of the page" award ...I can relate, my car is still a d15b2, too :-/
Old Oct 18, 2003 | 10:02 AM
ThatRicerDaniel's Avatar
Default Re: i have a ZC?!?! (ALL MOTOR EF8)
nawz that **** yo.
Old Oct 18, 2003 | 10:42 AM
4potnick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL MOTOR EF8 &raquo;</TD></TR><TR><TD CLASS="quote"> b20V in 88 crx 13.50 ALLMOTOR street tires</TD></TR></TABLE>Are you lost? I think you made a wrong turn?
91CivicEF
Jan 7, 2009 06:42 PM
91hfrex
Feb 23, 2006 10:38 AM
sohcvtecowns
Jul 1, 2004 03:16 PM
EsCo_EsCo
11
Jun 5, 2004 12:01 AM
daver
13
Jul 15, 2002 10:17 PM
