Need Help Please Car is missfiring
Old Apr 10, 2012 | 06:10 PM
CVCRDR's Avatar
Default Need Help Please Car is missfiring
i have 00 Si with a jdm type r missfires if i apply more than 20% throttle i replaced plugs wires dizzy cap and rotor fuel injectors fuel filter any suggestions are greatly appreciated im even pretty sure its just 1cylinder thinkingnext will be the fuel pump im trying to do it without paying a mechanic cause i can more than likely fix it myself if i can figure out what it is
Old Apr 10, 2012 | 06:53 PM
luvmihatch's Avatar
Default Re: Need Help Please Car is missfiring
ignitor? mine had break up and thats what it was.
u made sure your getting a good constant spark on all 4
Old Apr 11, 2012 | 05:25 AM
Xian's Avatar
+1 for possible igniter problems.
Old Apr 11, 2012 | 06:01 AM
CVCRDR's Avatar
Yup spark is good thanks I will check that out
Old Apr 11, 2012 | 07:07 AM
ekcoupeh22's Avatar
put a fuel pressure gauge on it and tape it to the windshield and drive to see if the pressure drops out on it
Old Apr 11, 2012 | 02:13 PM
luvmihatch's Avatar
meaning at high rpm. I would still find a known good ignitor and swap um.
Old Apr 12, 2012 | 09:54 AM
CVCRDR's Avatar
ok 1 problem type r motor but the dizzy cap is for a b18b non vtec so does that mean the whole distributor is for a b18b cause the igniter i just got from the store for a b18b is bigger
eternaltech
Nov 5, 2012 09:07 PM
syvpunk
Jul 29, 2010 04:10 AM
BUILTandBOOSTED
Jun 26, 2008 08:04 AM
hurleypooper
Feb 8, 2008 07:57 PM
turbod16y7vtec
Dec 5, 2004 08:39 AM
