How do I check codes in a 1991 accord lx??
Old Oct 11, 2002 | 03:42 PM
Monty's Avatar
Default How do I check codes in a 1991 accord lx??
Its a friends car so Im a little confused. Do i jump the little blue connector above the glove box and check engine light will flash? Or is it like the civic / integras where you get an led? I pulled the carpet back to find no led
very confused. Thanks for any help,
Monty
Old Oct 11, 2002 | 05:21 PM
bill-71SS's Avatar
Default Re: How do I check codes in a 1991 accord lx?? (Monty)
jump the conn.
Old Oct 14, 2002 | 12:39 PM
AccordVtec's Avatar
Just turn the key over, peel back the carpet under the passenger side.
Then there is a hole through the cover over the ECU, just look at the hole and it will blink, over, and over, count the blinks!
Old Oct 14, 2002 | 01:16 PM
GimpyAccord's Avatar
Default Re: How do I check codes in a 1991 accord lx?? (AccordVtec)
I think 90 was the last year on the Accords to have LED. My 91 LX you jump and the check engine light will proceed to blink your code.
Old Oct 14, 2002 | 02:21 PM
Monty's Avatar
Default Re: How do I check codes in a 1991 accord lx?? (GimpyAccord)
yeah no led in 91 I'll try the jumper. Does it store codes though?? The check engine light is intermittent(sp)
thanks
Old Oct 14, 2002 | 05:22 PM
I think it stores codes for up to 10 or 15 'running cycles' aka. key run/off ... don't quote me on that
Old Oct 14, 2002 | 08:26 PM
Howitt's Avatar
if your having trouble finding the jumper let me know it took me 2 hours to find it the first time, and the haynes manual was useless, there was like 4 guys looking for it eventaully found it under the kick panel, damn near in the door
Old Oct 18, 2002 | 03:28 PM
Monty's Avatar
Default Re: How do I check codes in a 1991 accord lx?? (Howitt)
Ok finally got back to working on it.
Code 17 = VSS
Is the Vss behind the speedometer?
Also The "S" (speed shift light) is flashing 4 times. Is this another code?
Thanks for any help
Old Oct 18, 2002 | 04:01 PM
Chiovnidca's Avatar
Code 17 = VSS
Thanks for any help
Probably a bad speed sensor. It's on the transmission.
90civicSiRacer
Oct 1, 2007 02:35 PM
aging-accord
Jul 21, 2007 09:20 PM
2kTeg
Jan 24, 2006 05:31 PM
abird
Aug 3, 2004 09:09 PM
