Loud gurgling/groaning after 3500rpm from exhaust.
Old Apr 9, 2012 | 09:19 PM
JGresch's Avatar
Default Loud gurgling/groaning after 3500rpm from exhaust.
Hey guys, any insite is appreciated.
basically my car sounds fine driving normal, coasting etc. But when I rev past 3500rpm, after I let off the gas(to coast or shift), my exhaust gets extremely loud. Its hard to describe the sound, but its a deep gurgle/groan.
For example if I'm at 4500 rpm and I let off the throttle, all the way from 4500->3500 I get this terrible sound, but as soon as I hit 3500 it goes away.
We looked for leaks and found a small one where my muffler tip attaches. But I don't think this is the problem. Think it could possibly be the inside of my resonator falling apart.
Exhaust is stock R all the way back to a T1R axle back if it matters.
TIA
Old Apr 10, 2012 | 05:29 AM
Dave_B's Avatar
Default Re: Loud gurgling/groaning after 3500rpm from exhaust.
Cat or Test pipe? Mileage on car? Header stock?
Old Apr 10, 2012 | 05:56 AM
CraterGrillo's Avatar
Could it simply be a vibration from part of the system touching the body of the car? I've had issues where the rubber hangers weren't quite right, and the rear muffler would trigger a horrible sound at certain rpms. Just a thought. If you check the clearance to the body it will be pretty obvious if that's what's going on.
Also, if you simply rev it in neutral, someone can listen from the side of the car to help pinpoint the problem if it is a hole.
Steve
Old Apr 10, 2012 | 08:02 AM
JGresch's Avatar
Thanks guys, I'll lift it up again and check for clearance, we did try to rev in neutral but it doesn't make the sound. Forgot to mention that.
Stock cat, stock header and 120km (75,000 miles) on motor/car
Old Apr 13, 2012 | 04:52 PM
Daniel_Bunny's Avatar
Same thing happened to me. I just added more rubber hangers to prevent all the vibration
Old Apr 14, 2012 | 02:55 AM
MiraiZ's Avatar
I would say its a leak for sure....look for cracks as well
Old Apr 14, 2012 | 07:30 AM
IanBlake's Avatar
Same thing happened to me, this is one of DC2 common problem, it is not a leak, this is the infamous rattling sound
https://honda-tech.com/tags.php?tag=rattling
danielm3
Welding / Fabrication
30
Dec 23, 2011 08:46 PM
mztykal
Feb 19, 2006 09:30 PM
redDAinteg
Sep 27, 2005 12:47 AM
HondaRacer32
Jan 21, 2004 06:55 PM
PatrickGSR94
Aug 31, 2003 04:20 PM
