JDM 1 piece fog light bulbs
Old Apr 9, 2012 | 03:41 PM
DA 4 Lyfe's Avatar
Default JDM 1 piece fog light bulbs
I have the JDM 1 piece headlights and one of my fog light bulbs blew out a few days ago. I tryed searching but couldnt find much other then aftermarket ones that I do not want. Any idea of where to buy a set brand new or even used if I have to? Tryed hmotors, passwordjdm, icb, jdm ****, extreme jdm with no luck..
Thanks guys
Old Apr 9, 2012 | 07:12 PM
el crapitan's Avatar
Default Re: JDM 1 piece fog light bulbs
just get raybrigs. h3. there may be some stanley's on ebay
they may be a spade connector, while yours is a bullet type. just fold the spade so it fits in the bullet type socket
Old Apr 9, 2012 | 07:24 PM
Lord Helmet's Avatar
http://jdmland.com/ they sell the piaa h3 in yellow. That's where I got my h3 replacement fog lights for my DA. Are you sure you checked ICB? I clicked that link I posted and they have what I wanted for my DA: headlights (h4h) and fogs (h3)
Old Apr 9, 2012 | 08:21 PM
i think he wants the oem stanley's.
op, did you check the ground? 1 piece fogs are notorious for corroded ground
Old Apr 10, 2012 | 01:05 PM
DA 4 Lyfe's Avatar
Yeah, checked the ground and the bulb is done. I put a h3 yellow bulb from my USDM 3 pc headlights and that one doesnt look at clean as the OEM jdm ones. The USDM's are too bright and I just want the OEM fog light bulb look again.
Old Apr 10, 2012 | 07:19 PM
the color should be defined by the wattage output. the lenses are clear, so just try and find the same watt bulb. unless you can get a description of the lumen output to compare. that would be even better
Old Apr 11, 2012 | 02:17 AM
ninjaturtleEG's Avatar
You dont have to fold the spade, the bullet time female connection has a slot and you can stick the spade in it. Thats what I do for spade to bullet connections.
Old Apr 11, 2012 | 04:16 AM
but the spade is too big to fit the bullet connector. from all the ones i've seen. never saw a slot on the female side of the bullet. just a round socket. maybe i'm missing something
GoldTeeth
Jun 19, 2011 03:32 PM
serg92hatch
Sep 20, 2010 12:42 PM
Poa
May 29, 2010 12:10 PM
ep3_andy
Sep 4, 2006 06:54 AM
SiHatchTurbo
Mar 31, 2006 08:12 AM
