Lug Nuts Stuck
Old Apr 9, 2012 | 01:52 PM
btadler's Avatar
Default Lug Nuts Stuck
I just took my car to the dealer to have a problem checked out and am now trying to rotate the tires and all the lugs are on so tight I can't get them off. Assuming they used a torque to put the lugs back on which is irritating none the less but my question is; What can I do to get these off other than taking my car somewhere?
Old Apr 9, 2012 | 02:11 PM
toyomatt84's Avatar
Sanji
Default Re: Lug Nuts Stuck
Do you have access to a breaker bar?
Old Apr 9, 2012 | 02:21 PM
btadler's Avatar
I could purchase one if I thought I would get more than this one use out of it. Of course it may be worth it since the alternative would be paying for a rotation.
Old Apr 9, 2012 | 02:23 PM
DELshaneSOL's Avatar
use a long pipe or the end of the jack pole
Old Apr 9, 2012 | 02:31 PM
toyomatt84's Avatar
Sanji
I use my breaker bar a ton, but that may be just me.
As for your situation, do you have a piece of pipe that can fit over your 19mm lug wrench?
Old Apr 9, 2012 | 02:33 PM
btadler's Avatar
Yea I just slipped that over and used it for leverage. thanks for the idea worked great. And I will consider the breaker bar since I am starting to do more of my own work now that I have a house not an apartment. Thanks again.
Old Apr 9, 2012 | 02:36 PM
ChristianL's Avatar
Take it back to the dealer, and make them remove the lugs, then hand-torque them to the proper limit (like they should have in the first place). Some guy with the gun just air-ratched them down tight. You're lucky your brakes aren't warping from that much over-torquing.
The same thing happened to me at a tire shop about 15 years ago, and I made them pay to replace the wheel lock they broke trying to get them off.
Atauto
Honda CR-V & Element
12
Sep 22, 2015 09:52 PM
corvair
Nov 2, 2009 04:15 AM
THEUSED
Aug 31, 2009 02:58 PM
94hatchvx
Jul 14, 2007 10:22 PM
Cliffjumper2
May 30, 2005 08:14 AM
