Clunking noise when shifting from park to reverse/vibration
Old Apr 8, 2012 | 01:42 PM
v-tec23's Avatar
Default Clunking noise when shifting from park to reverse/vibration
Recently everytime I back out of my driveway, especially in the AM, when going from park to reverse, theres a loud clunk noise. In addition when stopped at a red light, the engine tends to shake more than what it used to..any ideas or thoughts what these two problems could be or if there related to each other as they both seemed to have started at the same time...
Old Apr 8, 2012 | 03:41 PM
mitchk90's Avatar
Default Re: Clunking noise when shifting from park to reverse/vibration
Sounds like a bad transmission mount. Or an engine mount.
Old Apr 8, 2012 | 04:50 PM
v-tec23's Avatar
If it were the mounts, should I replace all at the same time? Also, I've heard people say its always best to go with OEM mounts rather than those sold on ebay for example. Does this sound right?
Old Apr 8, 2012 | 05:11 PM
v-tec23's Avatar
Old Apr 8, 2012 | 06:08 PM
mitchk90's Avatar
For a stock application, oem are the best. As for replacing all of them, it all depends how much money you want to spend. They usually run from 25-40 for the cheapest to 160 ish for the most expensive mount. But chances are if one is bad the rest are not to far behind. Also you can probably get the mounts cheaper than what I said above. All depends what place you go to.
devney
Mar 11, 2019 01:08 PM
debcolorado
13
Feb 3, 2013 07:07 PM
horsepowerless
Jun 19, 2012 11:45 AM
VTECcnIT
May 10, 2006 12:29 AM
Sleepy_Red_hatch
25
Dec 20, 2005 05:17 PM
