99 accord ac not working correctly
Old Apr 7, 2012 | 06:56 PM
TURBODC4TEG's Avatar
Default 99 accord ac not working correctly
hello my father has a 99 accord when he cuts the ac on the head button it only blows near his feet and not the center vents only the side vents. when u have it on head and feet only blows out at feet and side vents. what can i do to fix this
Old Apr 8, 2012 | 07:21 AM
Default Re: 99 accord ac not working correctly
anyone help
Old Apr 8, 2012 | 03:03 PM
joec44's Avatar
First what modle acd next you will need FSM fir this one get read it and follow the steps listed. this may be a real PITA. But if I had to make SWAG it is the mode door moter or wireing
Old Apr 9, 2012 | 08:55 AM
its a 99 lx 4dr. searched i don't see anything. this my fathers car and don't know much about accords
Old Apr 11, 2012 | 06:38 AM
up
Old Apr 11, 2012 | 07:23 AM
75aces's Avatar
You will need to open the cover over the ac control in the dash. The cable could be stuck.
Old Apr 11, 2012 | 07:43 PM
ok, im use to working on integra or civic. do i need to take the climate control out?
Old Apr 12, 2012 | 03:13 PM
75aces's Avatar
once it's loose, locate the cable that controls the vents in the dash. it's possible that they cable has gone bad.
Old Apr 12, 2012 | 04:55 PM
Bad_dude's Avatar
Icon3 Re: 99 accord ac not working correctly
They are all made by Honda, not too much of a difference.
Old Apr 14, 2012 | 04:23 PM
thanks smart ***
Old Apr 14, 2012 | 08:31 PM
spike32's Avatar
99 accord has no cable control, the motor door is controlled by electric. I have a 00 and it is the same controls
Old Apr 14, 2012 | 08:41 PM
75aces's Avatar
thats good to know.
Old Apr 14, 2012 | 08:55 PM
spike32's Avatar
oh, and to remove the control, you pop the clock out, there is a screw behind it, there is 2 more screws at the bottom of the radio trim. After you remove all 3 screws take the trim off.
This thread should be titled, Blower Controls not working. This is not an AC problem, title is misleading.
AFAIK, the side vents will always blow in all settings as long as the physical vent is open
You tried it on the floor and vent setting and you only feel is on the feet. What happens when you try the defrost setting, will it blow up by the front window ?
Are the LED indicators lit up and do they toggle when the buttons are pressed. If not the AC control is dead.
If the LED indicators are working normal, then go back and try the defrost mode and feel by the front window, the door motor may be an issue like joec44 said
Old Apr 14, 2012 | 10:55 PM
Bad_dude's Avatar
thanks smart ***
I was not trying to be. If you really look at what's under the hoods, you would notice much similarities. But I notice a few on this forum are quick to light the flame. Good luck to you.
Old Apr 15, 2012 | 05:24 AM
Lost Again's Avatar
Wouldn't you test the mode control motor before pulling the whole thing out?
Old Apr 15, 2012 | 07:30 PM
ok thanks, true i should have had a better title. yes when it is on feet only it blows on feet. when you have on defrost it seems to work. how much do the door motors go for? thanks all for your help
Old Apr 17, 2012 | 04:39 PM
Lost Again's Avatar
Have you tested the "door motor" aka the mode control motor as described?
grangey
Jun 25, 2010 09:18 AM
crc13
Mar 12, 2008 05:26 AM
greasemonky50
Feb 25, 2006 07:34 AM
2.3lcivic
Feb 15, 2006 11:47 AM
