auto j32a2 mating with a 6 spd tranny along with a auto harness. in a EG
okay so ive read ut have no answers yet so i need some help with this one. i have a EG and a auto j32a2 motor. i am buying a 6 spd tranny for it i also have the auto harness. what do i have to change on the motor to make this swap work? like will it work if i just swapped in the motor with out converting anything i dont care about CEL just care about drivability...
he is correct. lots of info on that site. browse first then join if you still have questions.
Also, yes you can run your auto ecu, but you need to trick it into thinking it's always in drive. or, you might be able to use a manual j32a2 ecu, or your only other option that i know of right now is the AEM EMS and that's about $1200.
in addition, with the stock ecu, you will need the original key or need to remove the immobilizer.
