Irratic Idle Problem, Please Help
Old Oct 11, 2002 | 12:43 PM
dubnine's Avatar
Default Irratic Idle Problem, Please Help
When my car is warming up and the Tach is at 1500 RPMS, the idle fluctuates. After the car is warm and the idle drops, its fine. But if i give it a little gas and hold it at 1500 RPMS, it will fluctuate. So this rules out the thought of a vacum leak. Even while driving it'll jerk if the RPMS is at 1500. Somebody please help.
Old Oct 11, 2002 | 01:20 PM
-Trinitron-'s Avatar
Default Re: Irratic Idle Problem, Please Help (dubnine)
My Si did that after i installed my new flywheel. I took off my IACV and cleaned it out and lowered the idle down. Reset your ECU by taking out the backup fuse for 10 mins. See if your car is throwing CEL code 14???
Old Oct 11, 2002 | 03:31 PM
dubnine's Avatar
TT.....
Old Oct 11, 2002 | 06:45 PM
FredoSP's Avatar
what are your mods? When did you first notice this. We'll need some more information about this. It could be plugs, wires, carbon on the throttle body.
Let us know
Old Oct 14, 2002 | 07:49 AM
dubnine's Avatar
Default Re: Irratic Idle Problem, Please Help (FredoSP)
Let us know
2001 b18c5, skunk2 intake manifold, 2001 p73 ECU/imobilizer removed, aem intake...
Old Oct 14, 2002 | 12:23 PM
dubnine's Avatar
ttt
Old Oct 14, 2002 | 12:30 PM
BoostedH23a1's Avatar
yea clean out the idle air control valve if that doesn help check out your PCV valve too..
Old Nov 10, 2002 | 07:08 AM
Integ718's Avatar
Default Re: Irratic Idle Problem, Please Help (BoostedH23a1)
Mine is doing pretty much the same thing I changed the TPS sensor, played with the idle screw adjusted the throttle cable and still no luck I am gonna try replacing my intake manifold.
Old Nov 12, 2002 | 08:46 AM
dubnine's Avatar
Default Re: Irratic Idle Problem, Please Help (Integ718)
Try a throttle body gasket. My ladies 98 GSR with a 95 throttle body was idling like this and we changed the throttle body gasket from an OBD2 to a OBD1 Gasket and its idling fine now.
michaelsej1
18
Feb 21, 2011 07:13 AM
tothewall
Oct 7, 2010 12:43 PM
followthadollar
Apr 20, 2010 06:23 PM
hondachris1994
10
Feb 25, 2006 02:37 PM
EsCo_EsCo
Aug 21, 2005 09:21 PM
