D16y8 fuel pump not engaging (solved)
Old Apr 6, 2012 | 08:16 PM
P-ridge28's Avatar
Default D16y8 fuel pump not engaging (solved)
I just swapped a d16y8 into my 00 civic and the fuel pump won't engage and the iacv is clicking but stops when I pull the sensor behind it any ideas I have to get this fixed by tomorrow
Old Apr 6, 2012 | 08:26 PM
Kustom X's Avatar
Default Re: D16y8 fuel pump not engaging
did you check if you have power to your fuel pump and try cleaning the iacv to see what happens
Old Apr 6, 2012 | 08:30 PM
P-ridge28's Avatar
Didn't cleAn iacv but the fuel pump engaged after I connected the thermostat housing ground , then it stopped engaging, this is what I did before asking question
Old Apr 9, 2012 | 06:55 AM
P-ridge28's Avatar
Fixed it my thermostat housing ground was loose
Freemananana
37
Sep 23, 2015 04:32 AM
Ek4 life
Jul 27, 2008 03:22 PM
charlee
Dec 6, 2006 09:09 AM
Schrader
Jun 25, 2005 01:03 PM
