vtec pressure switch
ive recently purchased a list of parts for my B20B/B16A ej8, and among the goodies is a chipped p28 i ordered from Phaerable.net. included with the ecu was a single sheet of literature. one line on this sheet states that i am required to bypass the vtec pressure switch on all jdm motors. this sheet also referred me to the tech section on their website for support on the matter. the tech support on their site is helpful, but i wanted to get some opinions on the matter. im told that this can be bypassed at the ecu or in the harness. i hit the search bar and came up short. if anyone who has performed this on their own car, or for someone else give me any advice or even provide a picture i would appreciate it.
not sure why they wouldn't have disabled it in with the chip, I had a chip from them in a P28 running a JDM obd1 b16 which has the pressure switch and I didn't have to do anything special , I am pretty sure phearable.net is mtber on here try sending him a PM for clarification, he's a good guy
Here you go...
one wire from the clip should be the VTEC pressure switch.
the other wire should be the VTEC solenoid.
solder both together. Then run wire from VTEC solenoid to where you soldered and solder that **** on there too and voila!
Backmarker
10
Sep 10, 2002 08:17 AM
