removing paint from wheels
Old Apr 6, 2012 | 12:55 AM
WhiteGSR95's Avatar
Default removing paint from wheels
just bought an fg2. the last owner painted the wheels black. what can i use to take off the paint and not take off the original wheel paint. or will i just have to clean them up to the bare rim metal?
Old Apr 6, 2012 | 04:14 AM
toyomatt84's Avatar
Sanji
Default Re: removing paint from wheels
You might be able to get it off with some brake cleaner and some elbow grease, but I wouldn't hold my breath.
Old Apr 6, 2012 | 07:22 AM
JiHyKim's Avatar
i think it would be easier to clean them all the way down. chemical cleaners are kinda all or nothing type.
good luck
Old Apr 6, 2012 | 08:54 AM
MonkeyMagic's Avatar
spray painted them right?
i'd try something like goof-off in a small spot. don't let any solvent sit on the rim very long. but the spray paint should succumb to any solvent long before the factory chemically-hardened/cured paint will. you'll probably struggle with paint near the center as heat from the brakes would've helped to better cure the spray paint.
it may look like crap when the spray paint comes off, but a polish meant for clear coat and a coat of wax should bring it back.
Old Apr 6, 2012 | 09:01 AM
79hatch's Avatar
If it was not a base coat clear coat over top of the factory paint a good amount of time with a scuff pad and some strong degreaser should do the job.
But I would suggest buying some air craft remover and just taking it to the bare wheel. Always makes for a better look after you get them redone.
Old Apr 6, 2012 | 09:23 PM
bigpunn421's Avatar
soda blaster
air craft stripper
the only 2 things i would reove paint with
Old Apr 8, 2012 | 01:50 AM
WhiteGSR95's Avatar
thanx for the replies. if i had a set of wheels and tires i would get them redone. i'll see what method i try. not sure when i will do it. but when i do i will post results
Eran
Jun 16, 2009 02:04 PM
mugenpowered
12
Aug 23, 2006 09:36 AM
hamadiscool
Jun 12, 2006 04:18 AM
peiku
Jul 25, 2005 10:49 PM
4DRmafia
Feb 24, 2005 11:55 AM
