Spark plug wire kit for non v-tec turbo b18c5??
The bottom of the boot that connects to no. 1 spark plug broke on me and now the spark plug cylinder area is filled with fuel and oil. Im guessing its not too big of a deal but i need to get a new wire kit, which one would be good for a turbo non-vtec low compression b18c5?
I know that but it no longer has v-tec.. It was deleted when the turbo was installed. Yes the boot that goes on top of the spark plug, the very end of it broke off inside and now there is fuel in there. When you look down you can't see the plug just fuel..
Yeah I will when I get home, so any reccomendations on wires? Also, any other info on the unburnt fuel that's in the plug cylinder area? Hope it's not messed
Idk how the spark plug boot ripping could cause fuel and oil to leak to there.
What ecu do you have any cels? Are you sure you have a vtec engine? Never heard of someone deleting it unless its a race motor w/ huge cams. Just cuz you can't hear it doesn't mean anything. Test it. What can you rev to?
My guess about the fuel in the spark plug cylinder was the wire gave out(which it did) and that plug was no longer working, then the car was running on 3 cylinders and all the I burnt fuel seeped up. Maybe the plug is a bit loose but I can't check it yet cause I can't get a socket on it because the debris from the broken boot is in there. I have to get it all out first. Hope I'm being clear, I'm trying lol
Lol silver ecu...check the code on the side and possibly open it up and take a pic of the inside and post it. Just to let you know, Hondata and all that mounts into the stock ecu so you can't tell just by swing a "silver ecu"
Ok ill take a look at it but can anyone give me any info on what I was asking? What kind of cables would be good? And do you think maybe that's why their is fuel in there(what I said above). No this isn't a troll thread.. I'm serious and need a bit of help. Thanks
Yeah it's defiantly fuel, it's dark so it looks like there is oil in it too maybe. It has a really quiet exhaust so I'm sure I'd hear it. I'll get the vin and pics when I get home, I'll order oem I guess. Thanks
No as said you won't really hear it with turbo. You can't just say cuz you can't hear it its not working. The less you can hear vtec is actually supposed to be better from a performance stand point
Well maybe it has it then, wouldn't I notice it on my rpm gauge or even feel it? I did in my other cars but they wernt turboed. All I know is the guy that sold me it said it was deleted. I'll have pics soon
LMAO, NGK wires (oem)
Please take your car to a good Tune shop and have them make sure everything is good. I wont be surprised if you blow the motor soon.
Can a mod please delete this thread? I was looking for help but all I have is a bad taste in my mouth now because "I have a project I don't understand". I'll find help elsewhere. Thanks to those who actually helped...
