Car will not even try to start
So i gotta 89 hatch that is dead. When you turn the key, there is no action (you do get dash lights and the fuel pump noise but that is it) there is not the annoying beeping either, it struggles to beep if you keep trying to turn the key over. starter is good . i dont know if its the neutral safety switch, ignition, ..... i am just stomped and need help.
struggles to beep? did you check the battery? spray a little starter fluid to help it start. if it starts with the starter fluid, then dies. then its a fuel issue, like injectors or something.
you can also take out the injectors and soak them in a cleaning agent like chemtool berryman b12.
