difference between si and dx crank pullies?
Old Oct 11, 2002 | 10:12 AM
dub204's Avatar
Default difference between si and dx crank pullies?
i used a dx crank pully on my si motor, and now the car wont start. there is spark and fuel. i'm pretty sure the timing is off, so i'm thinking that there might be a difference in the way the timing marks are set up?? because i have everything lined perfectly but its not starting.
Old Oct 11, 2002 | 11:08 AM
Zeppelin's Avatar
Default Re: difference between si and dx crank pullies? (dub204)
Other than the marks on the crankpulley, installing a different one will not change the timing. If you set the distributor in the middle of the range and it will not start then I would look elsewhere for your problem.
Old Oct 11, 2002 | 11:44 AM
dub204's Avatar
thanx!!
boostedteg69
Jul 28, 2011 02:02 PM
92hatchling
Mar 8, 2006 06:49 PM
distortion
17
Feb 3, 2006 12:55 AM
Kasper.
Dec 17, 2002 02:12 PM
