D16z6 overheating after hitting vtec
Old Apr 3, 2012 | 07:56 PM
GsO Redneck's Avatar
Icon2 D16z6 overheating after hitting vtec
Hey guys i just got a 95 ej1 to replace my ej2 that got stolen, im having a problem with the car overheating if i sit at a stoplight after engaging vtec. It's actually getting hot enough to boil the coolant. If i drive normally and keep it under say 4k rpm it wont overheat but it still gets really hot. I know for sure that the fan is not turning on and i just changed the radiator temp sensor to try and fix that. I attempted to change the thermostat but one of the bolts is stripped, im going to have my mechanic get the bolt off and change the thermostat for me. Is there anything else that you guys could think of that would be causing it to overheat?
Old Apr 3, 2012 | 08:05 PM
sohc-civic's Avatar
Default Re: D16z6 overheating after hitting vtec
its most likely your thrmostat.. change it and go from there, no use in spending money you dont have too.
Old Apr 4, 2012 | 06:21 AM
motegicivic's Avatar
For the fan jump the connector to make sure it runs.
Old Apr 4, 2012 | 01:05 PM
just jumped the connector and the fan runs but only if the motor isnt running
hotcivicsi
11
Apr 9, 2009 06:19 PM
92fourdoor
11
Jun 15, 2008 04:56 PM
jdmsol
Sep 14, 2003 09:40 AM
ek9si
Jun 18, 2003 04:42 AM
REDBARON
13
Nov 28, 2001 11:38 AM
