0bd0 vs obd1 injectors with resistor box
Alright so I just picked up a z6 swap. and it is using obd1 injectors(I assume, obd0 clips wont clip onto them) But my question is, there is a resistor box wired up to them? Will the obd1 injectors work even know there is a resistor box wired up? strange I know. Thanks for any replies.
You can either install OBD0 injectors and leave the resistor box; or delete the resistor box, change the injector clips, and use OBD1 injectors.
Considering that the clips are already OBD0, and the resistor box is already there, the easiest option would be to get some OBD0 injectors and throw then in there.
I have a set of injectors from a CRX if you need some.
Well the reason I say they are obd1 injectors is because obd0 clips wont fit on them and the clips that will fit on them are black instead of clear yellow color.
surkitroller
Dec 29, 2009 12:58 PM
racingant
Sep 28, 2005 05:10 PM
mr. Grind
Aug 15, 2004 12:13 PM
