B20 Motor into a 94 integra LS
Old Oct 11, 2002 | 09:59 AM
exactvox's Avatar
Default B20 Motor into a 94 integra LS
Hey,
We've just finished installing a B20 Motor into my Teg and was wondering if I can put a CRV 5sp ECU into the vehicle? and if I can use the RPM gauge from a CRV and put it into the LS Cluster? Oh yeah, I'm also running a Drag Gen III Turbo on the vehicle. Please let me know, much help is appreciated! <Complete 2001 CRV Motor>
Thanks,
Jay
Old Oct 11, 2002 | 10:02 AM
dubnine's Avatar
Default Re: B20 Motor into a 94 integra LS (exactvox)
I don't think there is a such thing as a CRV 5speed ECU.
Old Oct 11, 2002 | 10:06 AM
exactvox's Avatar
Default Re: B20 Motor into a 94 integra LS (dubnine)
I was checking up on the junk yards from http://www.car-parts.com, and they do have some 5speeds.
Old Oct 11, 2002 | 11:00 AM
Sleeper's Avatar
Why would you put an OBD2-3(97-01 CRV) ecu with a 6200rpm rev limit, when you have an OBD1(94 LS) ecu with 6800rpm already in the car? Why would you want the RPM gauge from a CRV? Whats wrong with the LS one? I don't know where you get your info but you need a new source.
CRV and LS heads are the same. All bseries engines use the same size fuel injectors, but different pressures. The 94-95 OBD1 LS ecu is hands down the best plug and play ecu for the B20.
Use the ECU from your teg, get an adjustible fuel pressure req and bump the pressure.
Old Oct 12, 2002 | 09:07 AM
exactvox's Avatar
Default Re: B20 Motor into a 94 integra LS (Sleeper)
Hey,
Thanks for the reply, it's just that I heard this from one of my guy at Skunk2. Running a B20 Turbo, 10lbs boost, and daily driven. I'm definately going to look through this more. I appreciate your help!
Thanks,
Jay
Old Oct 13, 2002 | 07:30 PM
B20Coupe's Avatar
welp for one...do you have a b20b or b20z....you'll need to know this b/c the ecu for the crv is different for each, b20b has 6200 rev limit...b20z has a 6800 rev limit. as far as the rpm gauge...its a whole cluster, you cant take out the rpm gauge and put it in your integra...and i dont know why you would...unless u wanted the amber lights, which u can get from the type r cluster...im running an obd1 ls ecu on my b20 and it works just fine...i think that the ls ecu will be better than the CRV one mainly because for the b20 "leaner is meaner"
Old Oct 13, 2002 | 09:09 PM
exactvox's Avatar
Default Re: B20 Motor into a 94 integra LS (B20Coupe)
Thanks for clearifying things up for me. I have people tell me differently, but I sure appreciate your help. As for the gauges, I always shift near redline, which is quite confusing when I put in a different motor. However, I'm already running the complete crv motor setup and about to reinstall my turbo kit. What kind of setup do you have on your car? I appreciate your help!
Thanks,
Jay
Old Oct 15, 2002 | 02:50 PM
JBONES's Avatar
i work at a honda dealer....they have a 5sp crv....i know it doest sound right......
jdmboy94
Oct 8, 2009 09:10 PM
98civdx
Sep 15, 2009 12:53 PM
96Integraracer
Oct 9, 2007 12:17 PM
BLUE EH3
Oct 14, 2005 06:28 AM
1hotcivicSi
30
Feb 16, 2004 03:15 PM
