turbo crx 1.6 lean.
i just turbo'd my crx 1.6 its stock i was wondering if i can use stock injectors on with a chipped p06 to compensate for it running lean or do i need to buy different injectors like 360cc's? Cause i have a wideband and a active pyrometer to tune the wideband shows lean and the exhaust temps go outtof control so def lean.
Ok so you turbo'd your CRX and did not know you need to upgrade the fuel system??? What are you doing with a turbo on the car then! Let me guess it is a Chinese Ebay turbo kit? Yeah get some DSM 450's and a 255 Walbro fuel pump and go to the dyno for some tuning. Oh you will need a OBD1 ECU that is chipped with something like Crome which is cheap and works for tuning. A PO6, P28 or OBD1 P75 will all work.
i have a p06 ecu and im chipping it myself this weekend so i got that covered i only plan on running 8 lbs so will i need 450's or will the 360's work? and i just picked up a walbro from my friend today, who also has the 360's.
DrivnMofo
11
Sep 12, 2005 08:48 AM
